Aruba ClearPass Universal Authentication Proxy - Attributes from JSON response
This thread has been viewed 29 times
  • 1.  Aruba ClearPass Universal Authentication Proxy - Attributes from JSON response
    Posted Dec 27, 2022 05:13 PM
    I have the Aruba ClearPass Universal Authentication Proxy setup and it is doing oauth with Microsoft Azure.  I have an HTTP authentication source (Configuration-> Authentication -> Sources -> HTTP)  that is requesting data from Microsoft graph.
    This looks to work correctly but the JSON that is returned has multiple values for what I want:
    value.0.displayName
    value.1.displayName
    value.2.displayName
    etc...  (there may be 1 or 10 or more returned in the JSON).
    Here is my filter query:
    /devices(deviceId=%{Endpoint:Intune Azure AD Device Id})/memberOf?$format=application/json;odata.metadata=none&$select=displayName
    This will return the JSON but I have to use multiple attributes like this:
    value.0.displayName | DeviceGroups-1 | String
    value.1.displayName | DeviceGroups-2 | String
    value.2.displayName | DeviceGroups-3 | String
    etc...
    Is there a way that I can put all of the value.X.displayName values together and return it as a single attribute?
    Here is the RADIUS/policy manager request log and what is being returned by the HTTP authentication source:
    2022-12-22 13:21:06,122 [HttpModule-ThreadPool-4-0x7fb3e986b700 r=R00000002-03-63a4a010 h=82] DEBUG Http.SyncHttpClientHandle - GET http://172.17.0.3/oauth2/devices(deviceId='xxxx-xxxx-xxxx-xxxx-xxxx')/memberOf?$format=application/json;odata.metadata=none&$select=displayName, statuscode=200
    2022-12-22 13:21:06,122 [HttpModule-ThreadPool-4-0x7fb3e986b700 r=R00000002-03-63a4a010 h=82] DEBUG Http.HttpAutzSession - Query response={"@odata.context":"https://graph.microsoft.com/beta/$metadata#directoryObjects(displayName)","value":{"displayName":"Group Tag - xxxx"},{"displayName":"Devices - xxxx"},{"displayName":"Device Test xxxx"},{"displayName":"Devices - Windows Corporate"}]}
    2022-12-22 13:21:06,122 [HttpModule-ThreadPool-4-0x7fb3e986b700 r=R00000002-03-63a4a010 h=82] DEBUG Http.HttpAutzSession - Flattened response={@odata.context:https://graph.microsoft.com/beta/$metadata#directoryObjects(displayName),], value.0.displayName:Group Tag - xxxx,], value.1.displayName:Devices - Windows,], value.2.displayName:
    2022-12-22 13:21:06,122 [HttpModule-ThreadPool-4-0x7fb3e986b700 r=R00000002-03-63a4a010 h=82] DEBUG Http.HttpAutzSession - query response:{@odata.context:https://graph.microsoft.com/beta/$metadata#directoryObjects(displayName),], value.0.displayName:Group Tag - xxxx,], value.1.displayName:Devices - Windows,], value.2.displayName:
    2022-12-22 13:21:06,122 [HttpModule-ThreadPool-4-0x7fb3e986b700 r=R00000002-03-63a4a010 h=82] DEBUG Http.HttpAutzSession - Query success urlpath=/devices(deviceId='db84473b-459b-48cb-a324-5c2a512b7de0')/memberOf?$format=application/json;odata.metadata=none&$select=displayName, attrs=>{}
    2022-12-22 13:21:06,122 [HttpModule-ThreadPool-4-0x7fb3e986b700 r=R00000002-03-63a4a010 h=82] ERROR Http.HttpAutzSession - Failed to get value for attributes=DeviceGroups]
  • 2.  RE: Aruba ClearPass Universal Authentication Proxy - Attributes from JSON response
    Posted Jan 02, 2023 07:19 AM
    This looks like a quite specific use-case, and I'm not even sure what you intend to achieve here. It may be good to work with Aruba Support to first find out if Universal Authentication Proxy would be the right solution to your requirements.
    Unless someone else has gone through the same and can share information here.
  • 3.  RE: Aruba ClearPass Universal Authentication Proxy - Attributes from JSON response
    Posted Jan 05, 2023 11:12 AM
    I am trying to pull the groups that the device is tied to and apply policies based on groups applied to the device.
