Original Message:
Sent: Sep 11, 2023 11:35 AM
Subject: Aruba compatible SFP
The AOS-S and AOS-CX Transceiver guide may help you in finding the right transceiver for a specific switch model, or compatible switch models for a specific transceiver.
Original Message:
Sent: Sep 08, 2023 06:27 AM
Really a pity that same overall model name is used for so many sub-models with quite different specs
spgsitsupport
Original Message:
Sent: Sep 07, 2023 01:27 PM
Yeah, sorry about that. All of the existing and the new ones are 2930F family.
I'll definitely buy 10Gb switches when we do a network equipment refresher.
Original Message:
Sent: Sep 07, 2023 11:30 AM
Hi
"Plus because the ports are SFP not SFP+"
I'm sorry about that, it was a pity not being able to go at 10G given the deployed fiber optic cable...but, ehi, you never explicitly wrote that you were dealing with an Aruba 2930F SKU not supporting SFP+ (like JL259A, JL260A, JL262A, etc.), one can't guess it so easily ;-) .
Original Message:
Sent: Sep 06, 2023 07:26 AM
Thanks everyone. I would like to get 10G between buildings but the factor is the cost.
48) RJ-45 autosensing 10/100/1000 PoE+ ports
(4) SFP
Original Message:
Sent: Sep 06, 2023 06:56 AM
The FS compatible reference J4859D is correct.
You should have no problem using it.
Frederic MEUNIER
Original Message:
Sent: Sep 05, 2023 09:45 AM
I need to connect two Aruba 2930F switches between buildings. The company that ran our fiber said we need to get single mode SFP, and this is what they recommended.
I just want to make sure this will work on the switches. Do I need to enter this command on the switch? The SFP is Aruba compatible.
https://www.arubanetworks.com/techdocs/central/2.5.2/content/switches/mrt/sw-allow-unspprtd-xcvrs.htm
J4859D HPE Aruba Compatible 1000BASE-LX SFP 1310nm 10km DOM Duplex LC SMF Transceiver Module for HPE OfficeConnect and ProCurve Switch Series - FS.com
FS.com | remove preview |
| J4859D HPE Aruba Compatible 1000BASE-LX SFP 1310nm 10km DOM Duplex LC SMF Transceiver Module for HPE OfficeConnect and ProCurve Switch Series - FS.com | J4859D HPE Aruba Compatible 1000BASE-LX SFP 1310nm 10km DOM Duplex LC SMF Transceiver Module for HPE OfficeConnect and ProCurve Switch Series, Product Specification:HPE Aruba Compatible - J4859D , Vendor Name - FS , Form Factor - SFP , Max. Data Rate - 1.25Gbps , Wavelength - 1310nm , Max. | View this on FS.com > |
