  • 1.  Aruba controller 7005-RW License lost
    Posted Sep 30, 2024 10:59 AM
    I bought a second-hand product to use 7005-RW It works fine  and I have factory reset my device and found that the license is missing
    can you help me to  recovery  my license? I have serial Numbers device I don't know this brand product if the factory default is restored, the license will be lost.
  • 2.  RE: Aruba controller 7005-RW License lost
    Posted Sep 30, 2024 05:48 PM
    You will need to contact Aruba TAC to help you out.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: Aruba controller 7005-RW License lost
    Posted Oct 01, 2024 04:50 AM
    Hi.
    Depend on how you did it. If you use "write erase all" or "wipe out" commands, then you need to contact the seller to provide you original license keys or open TAC case
    If you just use "write erase" licenses should be retained.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
