Become a Member
Hi. A new Cloud Mobility Controller 7010 running AOS 8.10.0.7 will not recognize any of the new access points Model 615 attached to the network.
AP 615 is supported from version 8.11 on. You have to upgrade your system. See Release Notes - https://www.arubanetworks.com/techdocs/ArubaOS/Consolidated_8.x_RN/Content/8.11/overview-8110x.htm
You'll need to ensure the Controller is running ArubaOS 8.11.0.0 or ArubaOS 10.5.0.0 as per the data sheet. Once the firmware version is correct, make sure the AP has a mechanism to locate the controller.
