  • 1.  Aruba Controller 9240 ACTIVE ACTIVE setup
    Posted 8 days ago
    team,
     we can configure 9240 controller as active active setup   for HA
  • 2.  RE: Aruba Controller 9240 ACTIVE ACTIVE setup
    Posted 8 days ago
    If you mean "Can we configure.." then Yes you can
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
  • 3.  RE: Aruba Controller 9240 ACTIVE ACTIVE setup
    Posted 8 days ago
    sir,
    can you share document for controller active active configuration?
    we have only 2 controllers
  • 4.  RE: Aruba Controller 9240 ACTIVE ACTIVE setup
    Posted 8 days ago
    AOS8 or AOS10?
    Willem Bargeman
    Systems Engineer Aruba
    ACEX #125
  • 5.  RE: Aruba Controller 9240 ACTIVE ACTIVE setup
    Posted 7 days ago
    Her is the reference for AOS10 clustering and Planning
    https://arubanetworking.hpe.com/techdocs/aos/aos10/design/gw-clusters/planning/
    and here is the one for AOS8
    https://arubanetworking.hpe.com/techdocs/ArubaOS/AOS_8x_WebHelp/Content/arubaos-solutions/cluster/clus-over.htm
