Aruba Controller administrator access with AD credentials
  • 1.  Aruba Controller administrator access with AD credentials
    Posted Sep 25, 2023 09:59 AM
    I use 6.4.4.6 version controller,
    Is it possible to integrate a RADIUS server for controller login, using my AD username and password in the GUI?
  • 2.  RE: Aruba Controller administrator access with AD credentials
    MVP
    Posted Sep 25, 2023 10:35 AM
    Yes it is possible.
    You have to Create the RADIUS Authentication with AD as source under:
    Configuration > Security > Authentication
    If you are using LDAP, then configure the necessary parameters on LDAP Server
    If you are using NPAS , then configure the necessary parameters on RADIUS Server
    After that, as step two, navigate to:
    Configuration > Security > Authentication > Server > Server Group
    Create a server group and select the above created Server (Either RADIUS or LDAP)
    After you finish the steps mentioned above, navigate to:
    Configuration > Management > Administration
    On the Management Authentication Servers, there is a space called Server Group. You select the Server Group which was configured above
    Shpat | ACEP | ACMP | ACCP | ACDP |
    -Just an Aruba enthusiast and contributor by cases-
  • 3.  RE: Aruba Controller administrator access with AD credentials
    Posted Sep 25, 2023 06:58 PM
    controller firmware AOS 6.x.x is end of support
    it is recommended to upgrade the later versions.
