aruba controller mesh ap multi hop problem
This thread has been viewed 26 times
  • 1.  aruba controller mesh ap multi hop problem
    Posted Jun 28, 2022 09:59 AM
    dear team
        i want config mesh multi hop ap, 1 mesh portal ,4 mesh point ,
    this is topology,Is the point automatically connected to other points? Do I need to do other configuration?
    leo ma
  • 2.  RE: aruba controller mesh ap multi hop problem
    Posted Jul 03, 2022 09:25 PM
    here are the guidelines. In an Instant mesh network, the maximum
    • Hop count is 2,
    • Number of mesh points per mesh portal is 8.
  • 3.  RE: aruba controller mesh ap multi hop problem
    Posted Jul 11, 2022 04:43 AM
    dear ariyap
      Is there automatic networking between point and point?
    leo ma
  • 4.  RE: aruba controller mesh ap multi hop problem
    Posted Jul 11, 2022 07:05 AM
    no it is not automatic, in either way it is better to make it predictable.
    check this technote that could give you ideas how to ensure the mesh point only connects to mesh portal of your choice.
    https://community.arubanetworks.com/community-home/digestviewer/viewthread?GroupId=13&MessageKey=3f3e4689-4dee-497f-aed5-6e6d5cf995da
  • 5.  RE: aruba controller mesh ap multi hop problem
    Posted Jul 11, 2022 07:59 AM
    sorry, This guide is from iap, i am ac+ap,I want to understand the ac+ap way,
    I tested 1 portal and 1 point, this is no problem, but when adding a point, this point will only connect to the portal, not to the point.
    this way of deployment:
    leo ma
  • 6.  RE: aruba controller mesh ap multi hop problem
    Posted Jul 11, 2022 06:35 PM
    well then you need to post your questions under "wireless access" subgroup, this sub-group is for controller-less Network.
    in either way here is the user guide for controller based mesh configuration.
    https://www.arubanetworks.com/techdocs/ArubaOS_8.8.0_Web_Help/Content/arubaos-solutions/mesh/secu-ente-mesh.htm
  • 7.  RE: aruba controller mesh ap multi hop problem
    Posted Jul 12, 2022 07:22 AM
    ok,thanks,i am try。
    leo ma
