The bounce will help with getting the client into the correct role. The status of the device might have changed. So instead of using a cached posture, it checks, updates the posture, and bounced the client to see if it matches something different. This is normal for a posture check as it updates the endpoint database.
Dustin Burns
Original Message:
Sent: May 05, 2021 11:21 PM
Subject: Aruba CPPM 6.7.13.110037 OnGuard without Bounce/Terminate Session for Healthy
Hi, I'm new on the OnGuard, does it have to be bounce even if the device is Healthy?
Richard Benedict
