Wired Intelligent Edge
  • 1.  Aruba CX 10K MACSEC support
    Posted Jun 11, 2025 05:03 PM
    Hi everyone,
    Does Aruba CX 10k switches support MACSec ?
    If yes, on which ports ?
    Thank you for your help
    Best regards
  • 2.  RE: Aruba CX 10K MACSEC support
    Posted Jun 11, 2025 11:55 PM
    yes MACSEC is supported in new  CX-10040  switch as per the datasheet
  • 3.  RE: Aruba CX 10K MACSEC support
    Posted 30 days ago
    But not on the 10000 model ?
    Best regards
  • 4.  RE: Aruba CX 10K MACSEC support
    Posted 30 days ago
    Hi, the Aruba CX 10000 does not provide MACsec on its ports (as instead, example, the Aruba CX 8360 does). Cheers.
