Here are the results of my tac case: the switches have a partioned TCAM, so the output of show capacities-status l3-resources
won't show any thresholds of the usage of the partitions. There are 6 partitions where 5 of them can be assigned to prefix lengths using the commands:
Any route with a prefix length other than the 5 named ones will use a "fallback" partition.
Sadly the documentation seems to not discuss this TCAM design nor does the CLI command have any reference how to use it.
ERT and lab has confirmed that it is only possible to check the TCAM partition usage using this diagnostic commands:
diagnostic
diag-dump l3 basic
WARNING: The dump command creates very long output (mine was about 35MB), you should consider to save it into a file and upload it afterwards.
At the very end of the dump the important details are listed:
HW ROUTE:
Entries: 52800
Table-Name Max-Capacity Available Filled
IPv4 Prefix Table 1 /24 393216 381887 11329
IPv4 Prefix Table 2 /23 65536 56028 9508
IPv4 Prefix Table 3 /22 16384 12153 4231
IPv4 Prefix Table 4 /21 24576 12574 12002
IPv4 Prefix Table 5 /20 65536 62459 3077
IPv6 Prefix Table 1 /44 393216 381887 11329
IPv6 Prefix Table 2 /40 65536 56028 9508
IPv6 Prefix Table 3 /36 16384 12153 4231
IPv6 Prefix Table 4 /32 24576 12574 12002
IPv6 Prefix Table 5 /29 65536 62459 3077
IPv4 BMP TCAM 65532 26000 39532
IPv6 BMP TCAM 32766 14760 18006
The size of the partitions (table 1 - 5 + BMP) are defined by the profile and you can reassign the prefix lengths to different partitions using the prefix-priority
statements.
So it seems that some micro management is required if you have more than ~10k routes (not prefixes, remind the ECMP factor). There is no notification if a partition gets overload nor is it possible to monitor this easily :-(
Original Message:
Sent: Jul 07, 2024 07:17 PM
Subject: Aruba CX 8360 Hardware Route, create failed for prefix
ok then perhaps it is best to reach out to TAC
Original Message:
Sent: Jul 07, 2024 03:59 PM
It's Core-Spine as it should support the max number of routes:
router# show profiles current
Current Profile
Core-Spine
Original Message:
Sent: Jul 05, 2024 08:42 PM
what is the output of "show profile current"
Original Message:
Sent: Jul 05, 2024 08:40 AM
I'm evaluating using Aruba CX 8360 for routing with a huge number of bgp routes. From the specs it should handle about 600k routes but that seems not to be unachievable.
The switch has learned less than 300k routes (ipv4+ipv6 combined):
router# show ip route summary
IPv4 Route Table Summary
VRF name : default
Protocol Active Routes
connected 6
local 7
ospfv2 324
bgp 3166
router# show ipv6 route summary
IPv6 Route Table Summary
VRF name : default
connected 6
local 7
ospfv3 73
bgp 125421
And the capabilities seems to be fine:
rtr-c1-dcg1# show capacities-status l3-resources
System Capacities Status: Filter L3 Resources
Capacities Status Name Value Maximum
Number of IP neighbor (IPv4+IPv6) entries 162 65536
Number of IP Directed Broadcast neighbor entries 0 1024
Number of IPv4 neighbor(ARP) entries 141 65536
Number of IPv6 neighbor(ND) entries 21 65536
Number of L3 Groups for IP Tunnels and ECMP Groups currently configured 38 2000
Number of L3 Destinations for Routes, Nexthops in ECMP groups and Tunnels currently configured 33 4093
Number of routes (IPv4+IPv6) currently configured 128880 631290
Number of IPv4 routes currently configured 3404 630780
Number of IPv6 routes currently configured with prefix 0-64 125473 598014
Number of IPv6 routes currently configured with prefix 65-127 3 510
After observing black holing through the router it seems that not all routes are getting into the FIB. I finally was able to find it in the syslog (/var/log/messages
) a huge number of logging messages for a random selection of prefixes:
2024-07-05T11:45:32.923337+00:00 router switchd_agent[3748]: debug|LOG_ERR|AMM|-|L3|L3_ASIC|Hardware Route, create failed for prefix: 2001:1A40:15FE::/47 vrf: 1 dest_id: 3 dest_fwd_type: route_ecmp_member dp_state: SINGLE due to OUT_OF_ROUTE. Total err_count=293514
Restarting the bgp sessions will trigger those messages again. It looks like if the FIB does not get the valid routes of the RIB and bricks the routing:
The hpe-routing daemon is running inside of the netns swns
and I assume it is not aware that the route is missing in the FIB. Other routers might use the switch as next-hop based on a routing protocol, but the switch will not be able to route the packet correctly (according to the RIB) if the route is missing in the FIB π€―π€―π€―
Any ideas?
