Wired Intelligent Edge
  • 1.  Aruba-CX and DUR from ClearPass
    Posted Feb 21, 2020 01:10 PM
    Hi there,
    I see some discussions about DUR and Secondary Roles, but I'm facing issues even with Primary roles and DUR.
    I configured the switch with a ta-profile, and my radius server has cppm user and password with permissions to download roles.
    I then setup a enforcement profile with type "Mobility Switch".
    My interface config:
    interface 1/1/3
        no shutdown
        description COLORLESS-PORT
        no routing
        vlan access 170
        spanning-tree link-type point-to-point
        aaa authentication port-access auth-precedence mac-auth dot1x
        aaa authentication port-access allow-cdp-bpdu
        aaa authentication port-access allow-lldp-bpdu
        aaa authentication port-access client-limit 8
        aaa authentication port-access mac-auth
            cached-reauth
            reauth
            enable
        exit
    I see the request on ClearPass, and it answers with the role.
    The switch log shows "2020-02-21T18:03:17.134578+00:00 f2sw01 port-accessd[3222]: Event|Unknown Event Name CERT_CHAIN_VERIFIED", meaning it is communicating with ClearPass.
    But no role is applied to the interface:
    # show aaa authentication port-access interface 1/1/3 client-status
    Port Access Client Status Details
    Client 00:xx:xx:xx:xx:xx, 000xxxxxxxx
      Session Details
        Port         : 1/1/3
        Session Time : 342s
      Authentication Details
        Status          : mac-auth Authenticated
        Auth Precedence : mac-auth - Authenticated, dot1x - Not attempted
      Authorization Details
        Role   :
        Status : Not Ready
      Session Details
        Port         : 1/1/3
        Session Time : 391s
        Role   :
        Status : Not Ready
    No errors are shown under event log.
    Can someone explain what should I configure for ARUBA-CPPM-ROLE attribute under ClearPass?
    I'm really starting to regret buying these half baked switches... No device fingerprinting support, no support on Clearpass, no DOCUMENTATION... Really miss my 2930f.
  • 2.  RE: Aruba-CX and DUR from ClearPass
    Posted Feb 21, 2020 01:24 PM
    Debug logs show:
    2020-02-21:18:21:38.490158|port-accessd|LOG_DEBUG|MSTR|1|PORTACCESS|PORTACCESS_ROLE|logID=507960 Result of download operation for role ROLE_AOS_CX_DUR_PHONE-3067-1 is No error
    2020-02-21:18:21:38.490519|port-accessd|LOG_DEBUG|MSTR|1|PORTACCESS|PORTACCESS_ROLE|logID=507961 Failed to parse XML file for ClearPass role 'ROLE_AOS_CX_DUR_PHONE-3067-1'
    2020-02-21:18:21:38.491156|port-accessd|LOG_DEBUG|MSTR|1|PORTACCESS|PORTACCESS_ROLE|logID=507961 DB operation Insert is successfully completed for role ROLE_AOS_CX_DUR_PHONE-3067-1
    Role is:
    user-role cppmrole
        vlan 174
        reauthentication-interval 1440
        voip-profile hq-wired_174
  • 3.  RE: Aruba-CX and DUR from ClearPass
    Posted Feb 21, 2020 03:06 PM
    What it the voip-profile XXX on the cppmrole ?
  • 4.  RE: Aruba-CX and DUR from ClearPass
    Posted Feb 21, 2020 06:34 PM
    A simple vlan only role also does not work.
    user-role cppmrole
    vlan 174
    I tried both Mobility Access Switch and ArubaOS. None work.
    Bounce Port CoA also does not work. Terminate CoA seems to terminate the session forever.
    Getting HTTP user agent info and DHCP (without ip helpers to ClearPass) for profiling also does not work/is non existent.
    Only thing that seems to work is standard radius attributes like tunnel-private-group-id to set the vlan; but that doesn't work for ACLs.
    Documentation is also severely lacking; some info is only found in AirHeads posts... Some other I got from a draft presentation from an Aruba representantive.
    Comparing the current state of 6300 to 2930, really makes it look like Switch Backwards, not Switch Forward.
  • 5.  RE: Aruba-CX and DUR from ClearPass
    Posted Feb 22, 2020 05:13 AM
    Hi ricard,
    I think, a ClearPass coming with feature for ArubaCX (for DUR)
  • 6.  RE: Aruba-CX and DUR from ClearPass
    Posted Feb 22, 2020 06:08 AM
    Also missing from AOS-CX Switches:
    - Framed IP Address on Accounting messages
    And I do have dhcpv4 snooping enabled.
    Exactly. AOS-CX 6300/6400 switches are currently not production ready for any network that uses ClearPass.
    If you need something that works today, go with HPE based AOS switches.
  • 7.  RE: Aruba-CX and DUR from ClearPass
    Posted Feb 22, 2020 06:34 AM
    I figured it out how to send a DUR to the switch.
    Syntax:
    class ip all-ipv4
    1 match ip any any
    exit
    port-access policy ALLOW-ALL
    10 class ip all-ipv4
    exit
    port-access role MANAGED
    auth-mode client-mode
    vlan access 170
    associate policy ALLOW-ALL
    exit
    Inside a Aruba-CPPM-Role radius attribute.
  • 8.  RE: Aruba-CX and DUR from ClearPass
    Posted Feb 22, 2020 03:00 PM
    Yes... the syntax on ArubaCX Switch...
  • 9.  RE: Aruba-CX and DUR from ClearPass
    Posted Feb 22, 2020 04:34 PM
    They should improve documentation.
