  • 1.  Aruba CX Switch not receiving the Role
    Posted Nov 16, 2023 08:41 AM
    Aruba CX Switch 6100 - version PL.10.10.1070
    Clearpass version 6.11.1.2513.04 (Cloud)
    Hello Everyone we are testing Clearpass for future implementation (POC with Trial Version)
    At the moment I was able to authenticate the user, Enforce the profile (with user role) to send to the Switch but i am facing a problem. On the switch side the port is not enforced with the correct Role
    I created the LUR-CX-CAMERA on the Enforcement Profile
    From Access tracker I am able to confirm the profile is correctly matching the device
    On the switch side I have the role created with the same name
    But the switch is assigning the default RADIUS_0 role
    Any idea about the issue? How can I troubleshoot this?
    Regards
    Tony
  • 2.  RE: Aruba CX Switch not receiving the Role
    Posted Nov 16, 2023 06:32 PM
    see if these commands can shed more light.
     "show event -r" and "sh port-access clients det"
  • 3.  RE: Aruba CX Switch not receiving the Role
    Posted Nov 16, 2023 06:59 PM
    Hello ariyap, thank you for the reply
    Form the show event -r i cannot see any log from radius
    With the sh port-access clients det i can see the default role
  • 4.  RE: Aruba CX Switch not receiving the Role
    Posted Nov 16, 2023 07:56 PM
    just reconnect the camera and then see the output of show event -r
  • 5.  RE: Aruba CX Switch not receiving the Role
    Posted Nov 17, 2023 03:32 AM
    Hello ariyap
    I tried again. no logs from radius
    All i have
  • 6.  RE: Aruba CX Switch not receiving the Role
    Posted Nov 17, 2023 05:08 PM
    see if you can upgrade to 10.10.1090 firmware.
    there was a resolved case where Clients are not updated with the latest role
  • 7.  RE: Aruba CX Switch not receiving the Role
    Posted Nov 23, 2023 09:05 AM
    Edited by Tony Gonçalves Nov 23, 2023 09:09 AM
    Hello
    Which debug commands can I use to see the information received from clearpass?
  • 8.  RE: Aruba CX Switch not receiving the Role
    Posted Nov 23, 2023 05:08 PM
    try this debug command
    debug portaccess all
  • 9.  RE: Aruba CX Switch not receiving the Role
    Posted Nov 23, 2023 06:21 PM
    I have found the issue.
    The service was activated with "monitor mode" ignoring any enforcement rules. My bad
    Thanks for the support :)
