Wired Intelligent Edge
  • 1.  Aruba CX Switch Simulator in Hyper-v
    Posted Feb 20, 2023 10:10 AM
    Hi
    Has anybody deployed the Aruba AOS-Switch on Hyper-V?
    it won't obtain ip on both the default vlan, first interface as well as the managmenet interface.
    Please share if there are any guides on how to deploy it.
  • 2.  RE: Aruba CX Switch Simulator in Hyper-v
    Posted Feb 20, 2023 10:32 AM
    Edited by thomasbnc Feb 20, 2023 10:41 AM
    There is a separate community for the simulator:
    https://community.arubanetworks.com/community-home?CommunityKey=aa40c287-728e-4827-b062-5eff4ed6410b
    Your problem is perhaps due to security restrictions on your virtual switch which doesn't allow the change/forging of MAC addresses.
    Did you try to enable "Enable MAC address spoofing" in the VMs Network Adapter's Advanced Feature Tab?
    Edit: I just checked the Release Notes of the simulator ... Hyper-V is not supported. Maybe you want to consider using GNS3 for this which is a great simulator environment which has already a lot of scripts/config integrated. https://gns3.com/software/download
    Thomas
