Just ordered a set of 8320s to replace our Core. Setup 2 test CX VMs on 10.04.001 to start working on the new config while I wait for the switches to arrive.
I'm using the Aruba0S-CX 10.04 Virtual Switching Extension (VSX) guide. The guide shows that I can use vsx-sync for vrfs.
switch(config)# vsx
switch(config-vsx)# no vsx-sync vrf
I do not see that is an option in the virtual platorm.
Core-1(config-vsx)# vsx-sync
aaa Sync all AAA instances
acl-log-timer Sync access-list log timer instance
arp-security Sync all ARP security configurations
bfd-global Sync all BFD global configuration
bgp Sync all BGP, ip aspath list, community list, prefix
list, route map configurations
copp-policy Sync all CoPP instances
dhcp-relay Sync all DHCP RELAY instances
dhcp-server Sync all DHCPv4-Server and DHCPv6-Server instances
dhcp-snooping Sync all DHCPv4-Snooping and DHCPv6-Snooping instances.
dns Sync all DNS instances
icmp-tcp Sync all icmp and tcp instances
lldp Sync all LLDP instances
loop-protect-global Sync all Loop-protect global configuration
mac-lockout Sync all mac lockout configurations
mclag-interfaces Sync QoS, LACP, Loop-Protect, LAG description, sFlow,
STP, Rate-Limits, Vlans, ACLs and Portfilters for MCLAG
interface instances
nd-snooping Sync all ND-Snooping instances.
neighbor Sync all IPv4 and IPv6 static neighbor entries
ospf Sync all OSPF instances
qos-global Sync all QoS global instances
route-map Sync all ip aspath list, community list, prefix list,
sflow-global Sync all sFlow global instances
snmp Sync all SNMP instances
ssh Sync all SSH instances
static-routes Sync all Static Routes instances
stp-global Sync all STP Global Configuration
time Sync all time instances
udp-forwarder Sync all UDP FORWARDER instances
vrrp Sync all VRRP instances
vsx-global Sync all VSX global configuration
<cr>
Can anyone confirm this is an option on 10.0.4.0001? Is it just an issue on the virtual?
