  • 1.  Aruba IAP cluster ClearPass authentication, untagged - tagged vlan
    Posted Oct 15, 2024 04:49 AM
    Edited by erik.boss Oct 15, 2024 04:59 AM
    Good day,
    I'm struggling with an issue.
    I want to autenticatie my Aruba Instant cluster with ClearPass. That works, the AP is found, receving the right untagged vlan.
    In my ClearPass config I have the tagged vlan set with the HPE Egress vlan ID.
    I can see in my Aruba 2540 switch the tagged vlans received.
    sh port-a cl 46 de
     Port Access Client Status Detail
      Client Base Details :
       Port            : 46                    Authentication Type : mac-based
       Client Status   : authenticated         Session Time        : 2137 seconds
       Client Name     : d015a6cbe80a          Session Timeout     : 10800 seconds
       MAC Address     : d015a6-cbe80a
       IP              : 10.10.31.104
      Access Policy Details :
       COS Map         : Not Defined           In Limit Kbps       : Not Set
       Untagged VLAN   : 31                    Out Limit Kbps      : Not Set
       Tagged VLANs    : 5, 6
       Port Mode       : 1000FDx
    When I want to connect to one of the SSID, I don;t receive an IP-address. The firewall is the DHCP server in this case.
    ClearPass will put my client in the right vlan.
    I've tried many switchport options, but ClearPass will push the tagged vlans.
    The client output in the switch
       Client Status   : rejected no vlan      Session Time        : 11 seconds
       Client Name     : 466c7c0cd922          Session Timeout     : 0 seconds
       MAC Address     : 466c7c-0cd922
    No user roles or whatever is used.
    What do I miss? I found other topics related to my issue, but did not work.
    Thanks for our reply
    Erik
  • 2.  RE: Aruba IAP cluster ClearPass authentication, untagged - tagged vlan
    Posted Oct 15, 2024 08:00 AM
    Hi Erik
    It looks like you are performing authentication of the wireless client in the switch as well to me. Is that correct?
    The right way to do this is to set the switch port to device-mode and not authenticate the wireless clients in the switch. Instead they should be authenticated in the access point.
    I think this is the correct Aruba Radius attribute to send:
    I often use Downloadable User roles, thus I'm a bit unsecure if it's the correct one.
    So in ClearPass you will authenticate the access point with a wired service, and the wireless clients with a service for wireless clients.
    Also for the troubleshooting, verify that the client VLAN works as intended by temporary configure a port without authentication and untagged VLAN 5 and connect a client. Does the client get an IP and is able to communicate normally.
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 3.  RE: Aruba IAP cluster ClearPass authentication, untagged - tagged vlan
    Posted Oct 15, 2024 08:06 AM
    Hi Jonas,
    without authentication, static untagged vlan and tagged vlans it's works perfect.
    I'll try your suggestion.
    Erik
  • 4.  RE: Aruba IAP cluster ClearPass authentication, untagged - tagged vlan
    Posted Oct 15, 2024 08:17 AM
    Hi Jonas,
    my Aruba 2540 does not have the device mode option, CX is does.
    Do you mean this?
    device-profile name "default-ap-profile"
       untagged-vlan 31
       tagged-vlan 5,6
       exit
    device-profile type "aruba-ap"
       enable
       exit
    Thanks in advance
    Erik
  • 5.  RE: Aruba IAP cluster ClearPass authentication, untagged - tagged vlan
    Posted Oct 15, 2024 08:28 AM
    Do you have the command device port-mode in the switch?
    It's the same in 2930F and other AOS switches I have worked with. So I expect it to be present also in 2540:
    Best Regards
    Jonas Hammarbäck
    Aranya AB
  • 6.  RE: Aruba IAP cluster ClearPass authentication, untagged - tagged vlan
    Posted Oct 15, 2024 08:50 AM
    Switch(config)# aaa authentication port-access
     local                 Use local switch user/password database.
     eap-radius            Use EAP capable RADIUS server.
     chap-radius           Use CHAP (MD5) capable RADIUS server
    No auth-mode even on the 3930M as on the 2540.
    Erik
  • 7.  RE: Aruba IAP cluster ClearPass authentication, untagged - tagged vlan
    Posted Oct 15, 2024 11:28 AM
    You can create a local user role on the switch, configure the role to include device-mode operation.
    https://www.arubanetworks.com/techdocs/AOS-S/16.11/ASG/YC/content/common%20files/aaa-aut-use-rol-nam-por-mod16.htm
    Or, return the HPE-Port-Dot1x-Port-Mode VSA that puts the port in device mode.
    https://community.arubanetworks.com/discussion/mac-authentication-aos-s
    Carson Hulcher, ACEX#110
  • 8.  RE: Aruba IAP cluster ClearPass authentication, untagged - tagged vlan
    Posted Oct 17, 2024 08:10 AM
    Going to implement this, sounds awesome :-)
