That's not a recommended architecture. Instant APs should have a management network/VLAN as untagged to it's ethernet uplink port, and the client VLANs as tagged.
You should enable VLAN 30 on the blue switch infrastructure, as well implement routing/DHCP services there to get a recommended architecture.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Mar 18, 2025 01:09 AM
Subject: Aruba IAP Cluster Configuration Issue
Based on the network diagram provided, I need help configuring my IAP (Instant Access Point). My network architecture has:
- The upper network layer in VLAN10
- A lower network in VLAN30 (192.168.3.0/24)
- VC (Virtual Controller) at 192.168.1.10
- AP at 192.168.1.20
- Both the AP and VC appear to be in VLAN30 with access to VLAN10
I need to configure my IAP so that:
- The upper network layer does not need to configure VLAN30
- The AP will assign IP addresses from the VLAN30 subnet (192.168.3.0/24) to wireless clients
- Traffic from VLAN30 needs to reach the upper network (VLAN10) and the internet
Problem I'm facing: I've already tried to set up a DHCP server on the VC. When I connect to the AP that's directly connected to the VC, I can get an IP address and the network works fine. However, when I connect to other APs in the cluster, I cannot get an IP address and the network is unreachable.
How should I properly configure the IAP to ensure all APs in the cluster can provide IP addresses to clients and maintain network connectivity?"
