  • 1.  Aruba IAP - Existing Cluster
    Posted Sep 17, 2021 10:27 AM
    Hello all,
    If I have an existing IAP cluster and an IAP is removed and the config of the remaining VC changes what happens when an IAP with an older config is reintroduced into the cluster? Is there a way that the returning AP could overwrite the existing config or is there a configuration version control system to stop this happening so that the version with the highest number win?
    Jason
  • 2.  RE: Aruba IAP - Existing Cluster
    Posted Sep 17, 2021 11:04 AM
    If you re-join an AP to a running cluster, it will take the configuration from the running cluster and the at that point running VC.
  • 3.  RE: Aruba IAP - Existing Cluster
    Posted Sep 17, 2021 11:41 AM
    Hello Herman,
    Thanks for the reply.
    What would happen if the cluster was rebooted then an AP with an older config was connected to the network before the other cluster APs came back up. Would they inherit the config from the older AP as it would be the network VC?
    Jason
  • 4.  RE: Aruba IAP - Existing Cluster
    Posted Sep 19, 2021 08:41 PM
    It is possible for that to happen yes.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
