  • 1.  Aruba Instant AP IPSEC\gre tunnel
    Posted May 16, 2019 04:21 AM
    Hello Airheads,
    we have a customer who has multiple sites with clusters of 5 or 6 IAP's.
    They would like to tunnel (from the cluster) all guest traffic.
    I know that you can do this with an Aruba controller acting as a vpn concentrator, but can you do this with a NON-Aruba device acting as termination point?
    cheers
    pete
  • 2.  RE: Aruba Instant AP IPSEC\gre tunnel
    Posted May 16, 2019 06:12 AM
    - IAP supports VPN termination using either IPSec or GRE
    - GRE termination is supported with both Aruba and Non-Aruba devices supporting standard EoGRE
    - GRE using Aruba GRE uses UDP 4500 for secure control channel establishment with controller and uses GRE with configurable GRE type for all data connection
    - GRE using Manual GRE uses GRE with configurable GRE type for all data connection
    - IPSec termination is supported using either Aruba controller with Certs or Standard VPN end points for PSK
    Take a look at the Aruba Instant VRD for more info.
    https://community.arubanetworks.com/t5/Validated-Reference-Design/Aruba-Instant-Validated-Reference-Design/ta-p/508696
    https://community.arubanetworks.com/t5/Validated-Reference-Design/Aruba-Instant-Validated-Reference-Design-V2-0/ta-p/456734
  • 3.  RE: Aruba Instant AP IPSEC\gre tunnel
    Posted May 16, 2019 10:55 AM
    Thanks for getting back Craig,
    is there any supporting info for implementing the NON-Atuba solution.
    cheers
    pete
  • 4.  RE: Aruba Instant AP IPSEC\gre tunnel
    Posted May 16, 2019 11:06 AM
    Hi Pete,
    There is the online help (below) or also the User Guide which has a lot
    more information.
    https://www.arubanetworks.com/techdocs/Instant_41_Mobile/Advanced/Content/UG_files/VPN_Conf/ManualGre.htm
