  • 1.  Aruba Instant Centaurus
    Posted Feb 28, 2022 09:24 AM
    Hi, I'm unable to find the latest firmware for the Centaurus models. Last version available = 8.6.0.9_79813. Other firmware (Lupus, Gemini, etc.) has a version 8.9.0.2_83074 available.
    We have a few 225 & 275 AP's in the environment - is it possible that they reached end of support?
    Ivan
    Ivan Duvenage
  • 2.  RE: Aruba Instant Centaurus
    Posted Feb 28, 2022 10:47 AM
    Edited by IDuvenage Mar 01, 2022 12:47 AM
    8.6.xxx is the latest code that the AP-225s can run. They are not supported in 8.7 and beyond. Save for the AP-275s
    You can always use the release notes for each version to see what "Supported Hardware Platforms" can run it. the asp.arubanetworks.com portal is also helpful because you can filer out your AP-models, and see what downloads are available for that model.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
  • 3.  RE: Aruba Instant Centaurus
    Posted Mar 01, 2022 12:48 AM
    Not what I wanted to hear :) but thanks for the feedback. Much appreciated.
    Ivan Duvenage
