Wired Intelligent Edge
  • 1.  Aruba Instant ON 1930 JL680A Generic SFP
    Posted May 13, 2021 10:49 AM
    Edited by Greg_W Jun 04, 2021 03:37 PM
    Does the Aruba Instant on 1930 JL680A support Generic SFP Transceivers
    Sales support does not have an answer
    Update: I had purchased an Aruba 2930f and I was able to download software updates without a support contract; recently they changed that and made it so you cannot download software updates unless you have a support contract. I gave up on hp / aruba and cancelled an order for 1000+ switches.
    Time to find a new vendor
    Husam Zadain
  • 2.  RE: Aruba Instant ON 1930 JL680A Generic SFP
    Posted May 13, 2021 04:22 PM
    Hello @HZ34
    I believe it doesn't...in the sense they are not "supported" simply because any 3rd Party Transceiver is not an original HPE/Aruba option (this doesn't mean that they could work flawlessly...there is no guarantee and no support if something goes bad). Aruba 1930 hasn't the CLI and it doesn't provide a "allow unsupported transceivers" command as on ArubaOS-Switch based switch series...so at best you would just try with one (pick it up and try).
    Have a read here (interesting) and, anyway, keep an eye open on the Aruba Instant On 1930 Switch Series QuickSpecs (see below):
    Davide Poletto
  • 3.  RE: Aruba Instant ON 1930 JL680A Generic SFP
    Posted May 14, 2021 02:33 AM
    You can get coded optics from fs.com that work just fine at least on 2530/2930/6300/6400 even without the unsupported-transceivers command. We only use those.
