You can get controllers managed by Central in SD-Branch mode and in AOS-10 which is the newest version for controllers.
Reach out to your local Aruba team to discuss the possibilities to migrate to AOS-10. In that mode, you can use Cloud Guest as included feature in the foundation feature set.
Original Message:
Sent: Apr 22, 2021 08:04 AM
Subject: Aruba Mobility Controller Managed by Aruba Central
Hi Team,
I have few doubts about Aruba Central in Large WiFi Network for Hotels (275APs)
1. Can we managed Aruba Mobility controller with APs in Aruba Central
2. If Yes, Can we add Aruba cloud guest from the WiFi Network
Dinusha Chandrasinghe - MVP | ACMP | ACSP |ACCA
Network Engineer
Plexus Global (Pvt) Ltd
Colombo Sri Lanka
+94717327420
