Aruba Mobility Master VM resources
  • 1.  Aruba Mobility Master VM resources
    Posted Jul 04, 2019 04:34 PM
    Hi can someone explain me
    Is it possible to install Aruba Mobility Master 5k VM with lower vCPU, RAM resources than requirments require? lets say CPU/2 RAM/2? Disk size would match according requirments. I mean to increase Mobility Master vCPU and RAM resources based on client demand.
  • 2.  RE: Aruba Mobility Master VM resources
    Posted Jul 05, 2019 09:54 AM
    No, it is not, the VMM will do a check against cores, RAM, and disk and if it's not sufficient will not start up, or will size in accordance with the resources assigned. You cannot enable a VMM-5K with less than the resources required and identified in the installation guide.
