Network Management
  • 1.  Aruba on Prem Dashboard and Reporting
    Posted Apr 25, 2025 07:23 AM
    I have an Aruba On prem solution, however when running reports from Network in order to get the total bandwidth if i run it from today for the last 7 days i get 200G of data however if i then run the exact same report for the last 30 days or 2 weeks I get 40G of data.
    Is there any caching or any issues that will not allow me to get a site level data transfer usage for each month, also for reference the devices i am looking at have only been up for short of 3 weeks if this is an issue.
  • 2.  RE: Aruba on Prem Dashboard and Reporting
    Posted Apr 25, 2025 11:11 AM
    Is the Aruba On Prem solution, Central on Prem server or AirWave? Generally, the data over longer period of times averages out in the graph, but should show the values appropriately in the report data. What reports is that and can you provide output of both the reports (1 week and 2 week report)?
    Regards
    Gowri Amujuri
  • 3.  RE: Aruba on Prem Dashboard and Reporting
    Posted Apr 28, 2025 05:18 AM
    I am using Aruba On Prem, I am looking to obtain the total data sent and received each month, the devices have only been in for 18 days up to now. However if i pull an Infrastructure / Network report for the last 7 days for all groups i get 200gb of data, but if i then run a report over a custom range over 2 weeks i get 2gb of data. I would expect to see at least the 7 day 200gb and then a bit more.
    Any suggestions, is this a limitation on the data, my worry is when the monthly report is run for the last calendar month it will not give the data that i need.
  • 4.  RE: Aruba on Prem Dashboard and Reporting
    Posted Apr 28, 2025 08:12 AM
    Hi, there isn't an Aruba product called simply "Aruba on Prem". There is instead, as example, a product called "Aruba Central (On Premises)", are you referring to this latter one or what? Cheers.
  • 5.  RE: Aruba on Prem Dashboard and Reporting
    Posted Apr 28, 2025 08:15 AM
    Yes Aruba Central (On Premises)
