Network Management
  • 1.  Aruba OS-CX OOBM interface with TACACS+
    Posted Feb 08, 2023 05:46 AM
    We are using TACACS+ to perform operator's authentication on our network gears.
    This works fine today as we are using an inside administration VLAN to connect into the device.
    However we are seeking to use the OOBM port of the aruba switches in order to access the devices through an
    external dedicated network. Unfortunatelly we figured out that the TACACS+ protocol does NOT work on the OOBM port.
    We also have aruba mobility controllers, and we are using the OOBM port with TACACS+ successfully with them.
    So concerning the switches, is it a port configuration mistake, undocumented feature, or is it there by "design"?
    Any experience shared in his area is welcome.
    Ray
  • 2.  RE: Aruba OS-CX OOBM interface with TACACS+
    Posted Feb 10, 2023 03:35 AM
    Is your OOBM port in the mgmt VRF? If so, did you assign the mgmt vrf (or vrf where your OOBM is in) to your tacacs server definition?
    Documentation:
    tacacs-server host {<FQDN> | <IPV4> | <IPV6>}
       [key [plaintext <PASSKEY> | ciphertext <PASSKEY>]]
       [timeout <TIMEOUT-SECONDS>] [port <PORT-NUMBER>]
       [auth-type {pap | chap}] [tracking {enable | disable}] [vrf <VRF-NAME>]
  • 3.  RE: Aruba OS-CX OOBM interface with TACACS+
    Posted Mar 14, 2023 01:53 PM
    Sorry for that late reply, but I have away for a while.
    So, as you suggested, adding the VRF "mgmt" context in TACACS, SNMP and SSH fix most of the issues I have on OOTM.
    However there is still one left:
    We are using IMC to manage our heterogenous park of equipments, and also using it for device backup.
    Unfortunatelly I have not been able to backup my OS-CX switch connected with OOBM.
    As an example, IMC uses the command "copy startup-config tftp://IMC_SERVER/backupfile.cfg cli"
    If I run this command - with the same IMC credentials - I get the error "curl: (28) Network is unreachable", which is obviously not the case.
    (FYI I get also the same error if I try to ping "anything" !?!.)
    So is there a ACL which prevent TFTP, ICMP (or maybe other services) to run on the OOBM port?
    Shall I try with SCP or SFTP?
    Any comment or suggestion is welcome.
