Wired Intelligent Edge
  • 1.  Aruba OS-CX stacking 8320
    Posted Jan 31, 2020 07:02 AM
    I have two aruba 8320 switches, which I want to stack similiar like a ifr-stack (Comware).
    I only need these switches for layer 2 connection to connect some servers. The switches should be connected to a Firewall, which is the layer 3 routing device.
    Regards
    Chris
    #8320
  • 2.  RE: Aruba OS-CX stacking 8320
    Posted Jan 31, 2020 08:38 AM
    The 8320 use VSX Stacking, you can look VRD ref guide for how to configure
    (there is always 2 management controller with VSX)
  • 3.  RE: Aruba OS-CX stacking 8320
    Posted Feb 02, 2020 05:18 AM
    Here is a good video expaining vsx.
    It is different then irf/vsf because it does NOT merge/virtualize the control plane of both switches into 1. Control plane is always separated and the maximum number of cluster nodes is limited to 2 devices.
  • 4.  RE: Aruba OS-CX stacking 8320
    Posted Feb 10, 2020 08:29 AM
    thanks for your quick reponses.
    Do I need to use the active gateway configuration in this setup?
    Regards
    Chris
  • 5.  RE: Aruba OS-CX stacking 8320
    Posted Feb 10, 2020 08:57 AM
    if the switch is only Layer 2, don't need Active Gateway
