in Aruba 8400, there is a concept of "local-priority" where you can map certain DSCP values to output queue without touching 802.1p value in the L2 header of the packet.
In Aruba OS 3810/5400, it seems that I must modify 802.1p value or change the "QOS QUEUE-CONFIG" (which maps 802.1p value to out queues) to be able to map certain DSCP value to output queus.
Is there any way to map certain DSCP value to different output queu in 3810/5400 without modifying 802.1p value in the packet?
