Network Management
  • 1.  Aruba OS Switches: PXE Boot over LACP Trunk doesn't work
    Posted Jul 19, 2021 02:34 PM
    Hello!
    I ran into an issue regarding PXE Boot over trunked Interfaces (LACP). A server is connected to a Aruba 5406R zl2 over 2 interfaces, which are configured into a lacp-trunk and runs fine so far during normal operation. But sometimes the server needs to be reinstalled over PXE. This doesn't work, because during the pxe-boot the server doesn't send LACP BPDUs and therefore the connection doesn't come up. On Juniper-EX Switches there was a solution with the option 'lacp force-up', which enabled one of the trunked interfaces as a single link.
    I can't find a solution for this on the Aruba Switches. Any help would be appreciated!
    Kevin Haarseim
  • 2.  RE: Aruba OS Switches: PXE Boot over LACP Trunk doesn't work
    Posted Jul 22, 2021 06:24 AM
    ArubaOS ? ArubaCX ?
    Because there is a same option with ArubaCX
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Aruba OS Switches: PXE Boot over LACP Trunk doesn't work
    Posted Jul 22, 2021 08:05 AM
    The Switch runs on ArubaOS
    Kevin Haarseim
