Network Management
  • 1.  Aruba S1500-24P
    Posted Nov 02, 2018 11:38 AM
    I do not know if this is the correct thread but I can't seem to find one dedicated to switch configuration.   My story goes like this.  My pastor purchased three HP Aruba S1500-24P Mobilty Access Switches.  This switches are intended for a standalone environment.  We can configure the switches just fine but when the switches reboot, it looses all of its settings and goes back to initial settings.  I have searched for a while now but I cannot find a solution.  My thought is that these switches require a Aruba-Central to work and pull their config.  Can I get this switches to save their configs and work as a standalone switch?
    I have attached the initial running and startup configs.
    Thank you,
    Brad Foreman
    Attachment(s)
  • 2.  RE: Aruba S1500-24P
  • 3.  RE: Aruba S1500-24P
    Posted Nov 05, 2018 09:01 AM
    Yes, I have tried write memory.   It tells it is successful.
    (ForemanSwitch) (config) # enable secret
    Password:*********
    Re-Type password:*********
    (ForemanSwitch) (config) #write mem
    Saving Configuration...
    Save failed: Admin password same as default password
    Use "mgmt-user admin" command in configuration mode to change the admin password.
    (ForemanSwitch) (config) #mgmt-user admin
    % Incomplete command.
    (ForemanSwitch) (config) #mgmt-user admin ?
    <rolename>              Role name from one of the following:
                            root - super user role
                            guest-provisioning - guest provisioning role
                            network-operations - Network operator role
                            read-only - Read only role
                            location-api-mgmt - Location API Management Role
    (ForemanSwitch) (config) #mgmt-user admin root
    Password:*********
    Configuration Saved.
    But when I restart, it nevers saves it.
    Brad
