SD-WAN
Aruba Sd Branch- Tunnel GRE over IPSEC
  • 1.  Aruba Sd Branch- Tunnel GRE over IPSEC
    Posted Jun 17, 2024 07:01 PM
    I was trying to configure a GRE Tunnel over VPN IPSEC, between an Aruba SD Branch and a Watchguard, but was unable to establish it.
    Has anyone set up this tunnel?
    Regards.
  • 2.  RE: Aruba Sd Branch- Tunnel GRE over IPSEC
    Posted Oct 11, 2024 10:27 AM
    Have you tried the settings that follow 'pass-through' tunneling with a cloud endpoint?
    Seems like the answer is hidden. Specific IPSEC configurations can then be applied. I'm interested to know if you have succeeded. I'm facing a similar question.
