Aruba SD-WAN Branch to VPNC Route
  • 1.  Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 12:10 AM
    Hi Community,
    I have deployed a Branch Getway and VPNC in our Office. I can see VPNC directly connected VLANs advertised in-branch gateway and branch routes in VPNC as Overlay route. But I can't reach the devices in that network from the branch network.
  • 2.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 12:31 AM
    most likely the IP addresses that you are trying to ping from your branch vlans have a default gateway that is not the VPNC.
  • 3.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 01:20 AM
    Branch Gateway VLAN interfaces default gateway is in the Branch Gateway. So how should it create Access VLANs in Branch Gateway
  • 4.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 03:50 AM
    I mean the default gateway for the IP addresses that reside in head end where VPNC is installed.
    What is teh default gateway for those IP addresses? is it the VPNC?
  • 5.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 04:03 AM
    Branch VLAN  (vlan40) default gateway is in the branch gateway interface. VPNC VLAN (vlan20)   default gateway is in the VPNC interface.
  • 6.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 09:49 AM
    Can you share a network diagram of the connectivity you're working with?
  • 7.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 09:47 PM
    already attached above question
  • 8.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 10:43 PM
    so basically your ping from 172.16.20.50 to 192.168.40.x fails?
    if this is a test setup ensure branch gateway is not directlly connected to VPNC (as you have it in your diagram), have a clear layer3 separation.
  • 9.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 23, 2020 10:50 PM
    By directly connecting VLAN 200 we tried to demonstrate Layer 2 MPLS VPN connection.
  • 10.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 24, 2020 12:00 AM
    VPNC Routing table
    RouteNexthopProtocol
    0.0.0.0/0172.16.10.254static
    192.168.40.0/24default-vpnip-master-ipsecmap-20:4c:03:56:19:c2-mpls_primaryoverlay
     default-vpnip-master-ipsecmap-20:4c:03:56:19:c2-internet_lteoverlay
    172.16.10.75/32-connected
    172.16.10.0/24-connected
    172.16.20.0/24-connected
    192.168.200.0/24-connected
    Branch Gateway Routing table
    0.0.0.0192.168.1.254static
    192.168.40.0/24-Connected
    192.168.200.1/32data-vpnc-20:4c:03:56:29:a2-mpls_primary_mplsIKE
    192.168.1.0/24-Connected
    1.1.1.1/32192.168.1.254static
    8.8.8.8/32192.168.1.254static
    123.231.xxx.xxx/32data-vpnc-20:4c:03:56:29:a2-internet_lteIKE
    172.16.10.75/32data-vpnc-20:4c:03:56:29:a2-mpls_primary_mplsIKE
    172.16.20.0/24data-vpnc-20:4c:03:56:29:a2-mpls_primary_mplsOverlay
     data-vpnc-20:4c:03:56:29:a2-internet_lteOverlay
    192.168.200.0/24-Connected
  • 11.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 24, 2020 12:59 AM
    so what are you trying to ping and from where?
  • 12.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 24, 2020 01:42 AM
    I am trying to ping from VLAN 40 in branch tro VLAn 20 in VPNC
  • 13.  RE: Aruba SD-WAN Branch to VPNC Route
    Posted Jan 24, 2020 02:30 AM
    can you ping from the BGW with VLAN 40 as source  to VPNC's VLAN 20 interface?
