Wired Intelligent Edge
  • 1.  Aruba smart rate ports for 10G uplinks
    Posted Sep 10, 2020 02:53 PM
    Can the smart rate ports on the JL323A Aruba 2930M 40G 8 Smrt Rte PoE switch be used as a 10G uplink to a regular 10G port that isn't a smart rate port?
    Steve
  • 2.  RE: Aruba smart rate ports for 10G uplinks
    Posted Sep 10, 2020 03:04 PM
    I don't believe so. I think a non-smartrate port connected to a smart rate port will end up in a 1gb speed on the smartrate side. Link training is required.
  • 3.  RE: Aruba smart rate ports for 10G uplinks
    Posted Sep 10, 2020 04:23 PM
    Greetings!
    Yes, a 10G-capable HPE Smart Rate port is capable of connecting to a standards-compliant 10GBASE-T port at 10G speed.
  • 4.  RE: Aruba smart rate ports for 10G uplinks
    Posted Sep 10, 2020 05:54 PM
    Thanks Matt!
