Hi Jason,
You can look the github repo for Terraform provider but actually, there is only 1 release
you can also look ansible module but there is also actually some limitation (not all configuration are supported)
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Jan 10, 2025 11:29 AM
Subject: Aruba Support for Terraform Provider
Likely an ignorant question, so apologies in advance, but does the paid Aruba support "officially" support the Terraform provider for AOS-CX? No assistance needed with TF implementation etc, just looking to ensure operationally that before we go down this path that if there is some issue with the provider itself and or the API that Aruba does indeed provide support outside of the dev community. Thanks!
