Network Management
  • 1.  Aruba switch (CX) integration with CyberArk
    Posted Nov 22, 2024 04:37 AM
    Hi
    we are using 2930F switches, and - maybe - in the future CX-based switches. We need to change the SSH management flow, so connection must be via CyberArk / PSM
    With out-of-the box Cyberark implementation (i.e. Linux connector), it does not work. We see the "userid" is correctly sent to the switch, the pasword is retrieved from Cyberark, but the authenticaion finally fails. Direct connection - without PSM - works fine.
    Q : is anyone having a working solution for integration between PSM & Aruba switches
    Danny Bosman
    KBC Group - Belgium
  • 2.  RE: Aruba switch (CX) integration with CyberArk
    Posted Nov 26, 2024 06:37 AM
    What I see with most customers is that they use TACACS/RADIUS/RadSec for ssh access to the switches, and don't use local accounts on the switches. That provides a centralized audit trail, which is really hard to realize with local logins.
    Or is PSM RADIUS/TACACS based?
  • 3.  RE: Aruba switch (CX) integration with CyberArk
    Posted Nov 26, 2024 07:47 AM
    PSM / CyberArk is just a vault where (admin) userid + credentials are stored. Via a specific login string in PUTTY, we are able to retrieve the admin user password. In the background, PSM will than start another ssh sessions and 'paste' the userid + password in the login sequence of the switch. It's this step that fails, probably because the password is not pasted on the correct place in ssh. The switch itself is indeed configured to use TACACS.
    Just checking if some airhead already did this implementation :)
    Danny Bosman
    KBC Group - Belgium
