Hello faadi,
Following is an IGMP setup example p.22 :
https://www.arubanetworks.com/techdocs/AOS-CX/10.07/PDF/5200-7876.pdf++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
IGMP configuration example
The output of the following show running-config command shows an example of an IGMP configuration
with IGMP snooping.
On the 6400 Switch Series, interface identification differs.
switch# show running-config
Current configuration:
vlan 1
no shutdown
vlan 2
ip igmp snooping enable
ip igmp snooping version 2
ip igmp snooping forward 1/1/1
ip igmp snooping blocked 1/1/3
ip igmp snooping static group 239.1.1.10
ip igmp snooping static group 239.1.1.11
interface 1/1/1
no shutdown
no routing
vlan access 2
interface 1/1/2
no shutdown
no routing
vlan access 2
interface 1/1/3
no shutdown
no routing
vlan access 2
interface vlan2
no shutdown
ip address 20.1.1.1/24
ip igmp enable
ip igmp version 2
ip igmp querier interval 5
ip igmp robustness 5
ip igmp last-member-query-interval 2
ip igmp query-max-response-time 50
ip igmp static-group 239.1.1.1
In regards to the IGMP snooping it starts at p.47 of the same guide.
In regards to the Energy Efficient Ethernet:
switch(config)# interface 1/1/1
switch(config-if)# no energy-efficient-ethernetHope this helps!
-Alex-
Original Message:
Sent: Nov 10, 2022 06:15 AM
Subject: Aruba switches Dante AV setup
Hello there,
We have the below Aruba switches on campus:
Product Name : R0X25A 6410 Chassis
ArubaOS-CX Version : FL.10.07.0030
I have to setup Dante AV on capability on Aruba switches. Here are some of the requirments:
- Enable IGMP snooping (this has to be enabled under layer-2 vlan)
- Enable IGMP snooping Querier on one switch (I think this has to be done under SVI)
- Enable IGMP immediate/fast leave on switches (I think this has to be done under SVI)
- Disable Energy Efficient Ethernet on switches (how it is done?)
I would appreciate if anyone can guide me on the configuration
