That is a 'UNIX epoch timestamp' in milliseconds. It's basically the number of milliseconds passed since 1 Jan 1970 00:00:00 UTC. If you have a Linux system you can use the 'date' command to convert it to a human readable time by inserting a decimal . at the 4th position from the right (to convert milliseconds to seconds):
% date -d @1663175063.065
Wed Sep 14 19:04:23 CEST 2022
I also found a nice website where you can enter the timestamp which even accepts the timestamp without adding the decimal dot.
Original Message:
Sent: Sep 16, 2022 08:28 PM
Subject: Aruba Utilities user guide
What is the timestamps format? I got this timestamps value from the log file, under the column of TIMESTAMPS:
1663175063065
I appreciate if more info can be posted here.
thanks in adv.
Original Message:
Sent: Sep 10, 2015 06:30 AM
Good mobile apps do not need user guides, any new user should be able to figure out how to use an app as they go.
Nevertheless, some of these networking functions are unavoidably complex so I do have one. Here's an updated guide for Aruba Utilities, to reflect v102 of the app which is now published on the Play Store: .
Let me know please if it's missing anything.
Peter
