  • 1.  Aruba wlan bridge mode
    Posted Dec 25, 2018 09:02 AM
    Hi all
    i want to working in  mode that the traffic not go to the controller
    my net build with MM-VA and MD the AP connected to the MD
    and its fine but i want to create ssid that working even if the controller ununreachable .
    i config ssid in bridge mode and then connected to the ssid when i disconected the MD the radio AP becom orange and my connection go down...
    from what i now the bridge  can work without the controller when the client already connected..
    do i miss somthing ?
    the version of the controller 8.3
  • 2.  RE: Aruba wlan bridge mode
  • 3.  RE: Aruba wlan bridge mode
    Posted Dec 25, 2018 02:20 PM
    another question :
    can i provision IAP automatically to the controller without the converting setup if yes can you guide me how to.. ?
  • 4.  RE: Aruba wlan bridge mode
    Posted Dec 25, 2018 02:39 PM
    Bridge mode works the same with Campus APs or Remote APs.  The difference is that a remote AP expects to be at a remote location and it has options for survivability if the connection to the controller is distrupted.  A Campus AP does not have the same survivability options.
    IAPs can be converted automatically, but using Aruba Activate with a convert IAP to Remote AP rule:  https://community.arubanetworks.com/t5/Software-User-Reference-Guides/Aruba-Activate-User-Guide/ta-p/291600
