Wired Intelligent Edge
  • 1.  ArubaCX VSX
    Posted Feb 01, 2021 11:19 AM
    Hi All,
    This hopefully is very basic and my error.
    I have 2 CX Virtual devices my lab and trying to configure VSX before i implement for a customer. I have configured 2 x switches as  a VSX pair with VLAN 10 SVI and active gateways. I have then tried to configure another switch with a lag to the VSX pair and cannot get any pings across. the configs of the switches are below, any help would be appreciated.
    Dale
    CONFIGS
    VSX1
    ArubaCX6(config)# show run
    Current configuration:
    !Version ArubaOS-CX Virtual.10.04.3000
    !export-password: default
    hostname ArubaCX6
    user admin group administrators password ciphertext AQBapV0PtzAhx3DZtjx7M6JK40vQ16gKWBG9auwCb3urLahnYgAAABdSg4I4DI12tq6jiYyOyuUM4j61fcBHpdjcHyY4hCGIelmKhWy1SCX3rwTDufEWuGTQbHDOQyc8UAyqJHpKi14Segevtwnj+7F2Keh8qGlGeEj+ibt/xW9l2lQn7MKLDRDL
    led locator on
    vrf keepalive
    ssh server vrf mgmt
    vlan 1,10
    interface mgmt
    no shutdown
    ip dhcp
    interface lag 10
    no shutdown
    no routing
    vlan trunk native 1 tag
    vlan trunk allowed all
    lacp mode active
    lacp rate fast
    interface lag 12 multi-chassis
    no shutdown
    description To-VSF
    no routing
    vlan trunk native 1
    lacp mode active
    lacp rate fast
    interface 1/1/1
    no shutdown
    interface 1/1/2
    no shutdown
    lag 12
    interface 1/1/3
    no shutdown
    interface 1/1/4
    no shutdown
    vrf attach keepalive
    ip address 10.1.18.41/30
    interface 1/1/5
    no shutdown
    lag 10
    interface 1/1/6
    no shutdown
    lag 10
    interface 1/1/7
    no shutdown
    interface 1/1/8
    no shutdown
    interface 1/1/9
    no shutdown
    interface vlan10
    ip address 10.0.10.2/24
    active-gateway ip mac 00:00:00:00:10:fe
    active-gateway ip 10.0.10.1
    l3-counters
    vsx
    system-mac 00:00:00:ab:cd:01
    inter-switch-link lag 10
    role primary
    keepalive peer 10.1.18.42 source 10.1.18.41 vrf keepalive
    https-server vrf mgmt
    VSX2
    hostname ArubaCX5
    user admin group administrators password ciphertext AQBapf7slPngEh46m7DHHRE3GBubqovV5nEiT5EVI7ATW0XnYgAAACFoSgaRgy9WSE+06JmdyOXv9hyL0YJC7IGn0xVONkH2QkZHlJ5x7nWugjds9I71ePu5N2OvXx7iK+Db+UP77dwVSBwDmKsdz65kU17SECnLo9NPzoIbqEENT1l7IUV21UQ3
    led locator on
    vrf keepalive
    ssh server vrf mgmt
    vlan 1,10
    interface mgmt
    no shutdown
    ip dhcp
    interface lag 10
    no shutdown
    no routing
    lacp mode active
    lacp rate fast
    no shutdown
    description To-VSF
    no routing
    vlan trunk native 1
    lacp mode active
    lacp rate fast
    interface 1/1/2
    no shutdown
    lag 12
    interface 1/1/4
    no shutdown
    ip address 10.1.18.42/30
    interface 1/1/5
    no shutdown
    lag 10
    interface 1/1/6
    no shutdown
    lag 10
    interface vlan10
    ip address 10.0.10.3/24
    active-gateway ip 10.1.10.1
    l3-counters
    vsx
    role secondary
    keepalive peer 10.1.18.41 source 10.1.18.42 vrf keepalive
    ACCESS Switch
    hostname ArubaCX7
    user admin group administrators password ciphertext AQBapf9QegE3kKy25oNfKl1esnqRTEyeUfG+eF4w9taXzwZxYgAAAAaHw6LubVHE88ARakqhbkyRgGg119IHuz2tBpNnQMPWKjB1iDv+uKJOO4rlUwuNUEMLKFFxseD+jncz+/N5vIAjMHpkGZM/f5VQRJgKRBvhdR4fHxOilfgf+rSrf+nNx4mi
    led locator on
    ssh server vrf mgmt
    vlan 1,10
    interface mgmt
    no shutdown
    ip dhcp
    interface lag 122
    no shutdown
    description To-Distribution
    no routing
    vlan trunk native 1
    vlan trunk allowed 1,10
    lacp mode active
    lacp rate fast
    interface 1/1/1
    no shutdown
    no routing
    vlan trunk native 1
    interface 1/1/2
    no shutdown
    no routing
    vlan trunk native 1
    interface 1/1/5
    no shutdown
    lag 122
    interface 1/1/6
    no shutdown
    lag 122
    Dale
  • 2.  RE: ArubaCX VSX
    Posted Feb 02, 2021 05:09 AM
    Please share:
    show vsx status
    show lacp int m
    show vlan
    What is the source ip and destination IP for ping ?
    Where is connected the source ?
    Vincent Giles
  • 3.  RE: ArubaCX VSX
    Posted Feb 02, 2021 06:49 AM
    Thanks Vincent, appreciate the help ... But it looks like its all working after I restarted everything today very strange, fail over works also but takes a couple of seconds guessing that because its virtual etc
    Have included the outputs in case it helps anyone else or there is an error
    source is a vPC in Eve-Ng with ip 10.1.14.100/24 DGW: 10.1.14.1
    CX2 VSX CORE switch
    CX2# show vsx status
    VSX Operational State
    ISL channel : In-Sync
    ISL mgmt channel : operational
    Config Sync Status : in-sync
    NAE : peer_reachable
    HTTPS Server : peer_reachable
    Attribute Local Peer
    ISL link lag10 lag10
    ISL version 2 2
    System MAC 00:00:00:ab:cd:01 00:00:00:ab:cd:01
    Platform X86-64 X86-64
    Software Version Virtual.10.04.3000 Virtual.10.04.3000
    Device Role primary secondary
    CX2# show lacp interfaces
    State abbreviations :
    A - Active P - Passive F - Aggregable I - Individual
    S - Short-timeout L - Long-timeout N - InSync O - OutofSync
    C - Collecting D - Distributing
    X - State m/c expired E - Default neighbor state
    Actor details of all interfaces:
    Intf Aggr Port Port State System-ID System Aggr Forwarding
    Name Id Pri Pri Key State
    1/1/4 lag10 5 1 ASFNCD 08:00:09:be:8f:9d 65534 10 up
    1/1/1 lag12(mc) 1 1 ASFNCD 00:00:00:ab:cd:01 65534 12 up
    Partner details of all interfaces:
    Name Id Pri Pri Key
    1/1/4 lag10 5 1 ASFNCD 08:00:09:c3:08:62 65534 10
    1/1/1 lag12(mc) 2 1 ASFNCD 08:00:09:ea:25:e5 65534 11
    CX2# show vlan
    VLAN Name Status Reason Type Interfaces
    1 DEFAULT_VLAN_1 up ok default lag10,lag12
    14 VLAN14 up ok static lag10,lag12
    CX2# show mac-address-table
    MAC age-time : 300 seconds
    Number of MAC addresses : 4
    MAC Address VLAN Type Port
    08:00:09:ea:25:e5 1 dynamic lag12
    08:00:09:c3:08:62 1 dynamic lag10
    00:50:79:66:68:05 14 dynamic lag12
    08:00:09:c3:08:62 14 dynamic lag10
    CX2# show arp
    IPv4 Address MAC Port Physical Port State
    10.1.14.100 00:50:79:66:68:05 vlan14 lag12 reachable
    Total Number Of ARP Entries Listed- 1.
    CX2#
    CX3 - VSX core Switch
    CX3# show vsx status
    ISL version 2 2
    Device Role secondary primary
    CX3# show lacp interfaces
    1/1/4 lag10 5 1 ASFNCD 08:00:09:c3:08:62 65534 10 up
    1/1/1 lag12(mc) 1001 1 ASFNCD 00:00:00:ab:cd:01 65534 12 up
    Name Id Pri Pri Key
    1/1/1 lag12(mc) 3 1 ASFNCD 08:00:09:ea:25:e5 65534 11
    CX3# show vlan
    CX3#
    CX3# show mac-address-table
    08:00:09:be:8f:9d 1 dynamic lag10
    08:00:09:be:8f:9d 14 dynamic lag10
    CX3# show arp
    CX3#
    CX 4 - Access switch
    CX4# show lacp interfaces
    1/1/1 lag11 2 1 ASFNCD 08:00:09:ea:25:e5 65534 11 up
    1/1/2 lag11 3 1 ASFNCD 08:00:09:ea:25:e5 65534 11 up
    Name Id Pri Pri Key
    1/1/1 lag11 1 1 ASFNCD 00:00:00:ab:cd:01 65534 12
    1/1/2 lag11 1001 1 ASFNCD 00:00:00:ab:cd:01 65534 12
    CX4# show vlan
    1 DEFAULT_VLAN_1 up ok default lag11
    14 VLAN14 up ok static 1/1/3-1/1/4,lag11
    CX4#
    CX4# show mac-address-table
    Number of MAC addresses : 6
    08:00:09:c3:08:62 1 dynamic lag11
    08:00:09:be:8f:9d 1 dynamic lag11
    08:00:09:c3:08:62 14 dynamic lag11
    08:00:09:be:8f:9d 14 dynamic lag11
    00:00:00:00:10:fe 14 dynamic lag11
    00:50:79:66:68:05 14 dynamic 1/1/3
    CX4# show arp
    No ARP entries found.
    CX4#
    Dale Joyce
  • 4.  RE: ArubaCX VSX
    Posted Feb 02, 2021 07:10 AM
    I didn't pay attention you were talking about OVA...
    I would recommend to use 10.5 version.
    Vincent Giles
  • 5.  RE: ArubaCX VSX
    Posted Feb 02, 2021 08:06 AM
    Thanks Vincent .. I will do
