ArubaOS 8 HA Fast Failover, Client disconnects
  • 1.  ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 08, 2024 04:26 AM
    Dear Expert,
    Without Mobility Master, we have option for HA Fast Failover with standalone controllers. I have configured and checked on both controllers "show ha ap table" and both are showing AP connected. however for testing purpose when i disconnect primary controller, the AP starts showing on backup controller but client's communication is no longer going through and ultimately disconnects. I checked on the backup controller and no clients are showing there. I have single SSID working with Preshared key. Is it expected behavior?
  • 2.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 08, 2024 10:33 AM
    Expected would depend on whether or not you have things configured properly or not.  When don't correctly you should see the client move to the backup controller seamlessly.
    Be aware, HA fast failover is very sparsely used, clustering is the preferred HA method for seamless connectivity.  Most users not running a cluster will utilize either a VRRP pair or LMS/B-LMS for the failover.
    Please open a TAC case if you are wanting to troubleshoot your FF configuration.
    Carson Hulcher, ACEX#110
  • 3.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 08, 2024 11:00 AM
    Dear Carlson,
    I have a single vlan configured for Ap management and user for testing purpose. There is very minimal config required so what i might have done wrong?
    I created HA group, controllers as dual, state sync, then controllers assigned to ha group. Then ap group lms ip and backup lms ip configured. When i do show ha ap table i see ap on both controllers however client doesnt move upon failover
  • 4.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 08, 2024 11:08 AM
    No idea, that's part of why I recommended a TAC case.
    I haven't tried to make fast failover work since AOS 6.3, and wouldn't recommend the configuration for AOS 8.  If you need seamless failover, get an MCR and setup a cluster.  If you just need redundancy, use VRRP and/or LMS/B-LMS.
  • 5.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 08, 2024 11:38 AM
    oh ok, well i cant open the TAC Case unfortunately.
    We are trying to replicate customer setup who is running HA FF alongside VRRP and conductor redundancy. As far as i know these 2 are mutually exclusive and shouldnt be configured together.
  • 6.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 08, 2024 11:47 AM
    Can you just confirm below 2 points if possible based on your experience
    1) If all configured correctly, does HA FF allows clients to move seamlessly to backup controller if SSID is WPA2/3 Personal?
    2) I read on this forum that during HA FF, user table is not synced between controllers.
  • 7.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 08, 2024 09:03 PM
    Edited by chulcher Aug 08, 2024 09:03 PM
    HA FF will sync "high value" session information from the active to the backup controller.  That should provide a mostly non-interruptive failover for client devices when working properly.
  • 8.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 09, 2024 01:32 AM
    What is high value session
  • 9.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 09, 2024 09:15 AM
    TCP connections like FTP, Voice (with a priority and marking), and DPI are examples of high value sessions.
    You can check the output of the following command:
    show datapath session high-value
  • 10.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 15, 2024 09:57 AM
    See the user guide page on this topic.  Client will get disconnected, required to go through the 4 way handshake.
    https://www.arubanetworks.com/techdocs/ArubaOS_8.12.0_Web_Help/Content/arubaos-solutions/vrrp/clie-stat-sync.htm
  • 11.  RE: ArubaOS 8 HA Fast Failover, Client disconnects
    Posted Aug 08, 2024 11:03 AM
    Please note that i dont have MM
