ArubaOS 8 - Setting up Remote Access Point (RAP)
This thread has been viewed 231 times
  • 1.  ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted May 27, 2018 05:28 AM
    The post shows the step by step configuration in setting up a Remote AP (RAP) in ArubaOS-8 (AOS8) on a standalone controller
    This would be helpful for anyone new to AOS 8 and RAPs
    Information is based on ArubaOS Version 8.3.0.0
    Remote Access Points AOS6 versus AOS8
    In AOS6:
    In AOS8:
    Redundancy achieved by, terminating RAPs on VRRP-IP or LMS/BKP-LMS.
    High level of redundancy achieved by, terminating RAPs on Cluster
    On Controller failure, RAPs Bootstraps and clients are de-authenticated.
    Using L2 Connected Cluster, we can achieve Hitless AP failover and Hitless client failover.  We can also do RAP and Client load balancing.
    Points to Consider.
    Cluster is limited to max 4 nodes in case of RAP.
    If you have a cluster of 4 Mobility Controllers, We should configure public-ip in all 4 controllers. It might be changing in the upcoming release
    RAP will establish ipsec tunnels to all 4 controllers, but at any point of time only one A-AAC and on S-AAC will be established.
    How to configure a Aruba Controller to terminate RAPs:
    ArubaOS Version: 8.3.0.0
    Controller Model: 7005
    Controller Mode: Standalone
    AP Model: AP-303H
    Network Diagram:RAP Solution.jpg
    Bring up the Controller in Standalone mode:Standalone.jpg
    Install the Licence:
    RAPs do not require PEFV. Only the regular AP licenses (AP, PEFNG).
    Mobility Controller -> Configuration -> System -> Licensing
    Once Installed, Please ensure that "Feature Enabled" checkbox is ticked. This will enable the license.
    Make the Physical Connections:
    Aruba 7005 Controller - 0/0/0 - Connected to Internet (Public Network)
    Aruba 7005 Controller - 0/0/1 - Connected to My Lab (Internal Network)Port Status.jpg
    Create an L2 and L3 Interface:L2 and L3 Interfaces.jpg
    L2 and L3 Interfaces - Configuration snippet:L2 and L3 Config snippet.jpg
    Creating a user role for the RAP user:
    //listing all the internal network, I should have access to.
    netdestination internal-networks
        network 192.168.17.0 255.255.255.0
        network 192.168.26.0 255.255.255.0
        network 172.30.30.0 255.255.255.0
        network 172.30.29.0 255.255.255.0
    //Tunnelling internal network traffic to Controller and other traffic are source natted.
    ip access-list session split-tunnel
        any any svc-dhcp permit
        user alias internal-networks any permit
        alias internal-networks user any permit
        user any any route src-nat
    user-role System-Engineer
        access-list session global-sacl
        access-list session apprf-system-engineer-sacl
    Configure VPN Pool:
    Configuration -> Services -> VPN -> General VPN -> Add the Address PoolsVPN Pool Config.jpg
    Equivalent CLI Command:
    ip local pool "rap" 1.1.1.1 1.1.1.100
    If you have an MM and MD setup, to support Remote AP in cluster configuration, you need to use Cluster RAP Pool.
    In GUI, Goto MM -> MM-Node
    Configuration -> Services -> Clusters -> Controller Cluster RAP Pool
    In CLI, To Create rap pool on MM/mynode node
    lc-rap-pool cluster-rap-pool <StartAddress> <EndAddress>
    Define RAP AP Group and related settings:
    ap-group-profile contains virtual-ap-profile and ap-system-profile.
    virtual-ap-profile contains aaa-profile and ssid-profile.
    //user-role "System-Engineer" is linked to aaa-profile
    aaa profile "default"
        initial-role "System-Engineer"
        authentication-dot1x "default-psk"
    //Creating the ssid-profile
    wlan ssid-profile "Employee-ssid_prof"
        essid "KapilHome"
        wpa-passphrase "Aruba123!"
        opmode wpa2-psk-aes
    //aaa-profile and ssid-profile is linked to the Virtual AP Profile.
    wlan virtual-ap "Employee-rap-vap-profile"
        vlan 30
        aaa-profile "default"
    //Creating the ap-system-profile
    ap system-profile "rap-AP-system-profile"
        lms-ip 59.167.24.220
        ap-console-password "Aruba123!"
        bkup-passwords "CP0010727!+^>"
    //virtual-ap-profile and ap-system-profile is linked to the AP-Group
    ap-group "raphome"
        ap-system-profile "rap-AP-system-profile"
    Note:
    You can also create WLAN using the wizard under "Configuration -> WLANs".
    All the configuration are done on the "default" ap-group.
    Name you choose for ssid in WLAN Wizard, is used as name for virtual-ap profile, aaa profile, authentication-dot1x profile and ssid-profile.
    Whitelist the Remote AP:
    Aruba7005 -> Configuration -> Access Points -> Whitelist -> Remote AP Whitelist.Whitelist RAP.jpg
    Equivalent CLI command
    whitelist-db rap add mac-address "20:4c:03:21:85:2c" ap-group "raphome" ap-name "Kapil-RAP"
    DHCP Server on the Controller:
    This is to serve the clients on VLAN 30.
    This can be done under "Configuration -> Services -> DHCP -> DHCP Server" in GUI
    ip dhcp excluded-address 172.30.30.101 172.30.30.254
    ip dhcp pool pool30
     default-router 172.30.30.1
     dns-server 8.8.8.8
     authoritative
    service dhcp
    Provision the AP (Instant AP):
    Here we are converting an Instant AP (IAP) into Remote AP (RAP).
    I have got a brand new IAP. I need to Provision the Country Code and then convert to RAP.
    Just go to Maintenance -> Convert ->
    Select “Remote APs managed by a Mobility Controller”
    Enter the IP Address of the Mobility Controller
    Verification Commands:
    AP database:RAP Database.jpg
     AP bss-table:bss-table.jpg
     Interfaces on the RAP:Interfaces.jpg
    Different ways RAPs can be terminated on the Controller:
    Staged:               Any CAP APs can be staged to become a RAP
    Zero Touch:  RAPs have a GUI where the user can enter the IP address or URL of the controller.
    Activate: RAPs can also automatically communicate with Aruba cloud based Activate. If an entry exists in Activate it will direct these RAPS to the controller.
    Conversion: Instant AP can also be converted to RAPs by pointing to IP address of the Mobility Controller
     Hope you find this useful. Please post your feedback !
    Kapildev Erampu
  • 2.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted May 27, 2018 05:58 AM
    Thank you for the setup guide for the new OS ArubaOS 8.
    It has helped a lot.
  • 3.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted May 27, 2018 06:39 AM
    Welcome Mate :)
  • 4.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Jun 30, 2018 08:06 AM
    Could you help us to check why our RAP can not connect the VMC AOS8.3 ? please take a look the detail in the followed link
    https://community.arubanetworks.com/t5/Wireless-Access/Aruba-RAP-contact-to-public-IP-VMC-AOS8-3-problem-need-help/td-p/438204
  • 5.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Jul 01, 2018 08:35 AM
    Just had a look at the link you provided.
    Getting the output to the following commands would be helpful.
    show ap database
    show ap-group <ap-group-name>
    show wlan virtual-ap <vap-profile-name>
    show aaa profile <aaa-profile-name>
    show wlan ssid-profile <ssid-profile-name>
    What role is your user connecting to RAP placed in? Could you please issue "show rights role-name"
    Please email me the outputs to kapildev.erampu@hpe.com
    You can contact Aruba TAC using the below link. Just call them based on which country you are located.
    https://www.arubanetworks.com/support-services/contact-support/
    Kapil
  • 6.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Jul 01, 2018 09:19 PM
    Dear  Mr Kali
    We are very happy to get your reply as Aruba community as follow:
    and I think the followed information in not enough for you.
    you can access our VMC by the public IP 47.104.193.111 directly
    1. we have 1:1 nat and open all of policy in our firewall (any protocal included GRE, any tcp udp port)
    2. you can access our VMC by 47.104.193.111 and username is admin ,password is (We have send email to you kapildev.erampu@hpe.com for the password)
    3.This VMC is for test, So please do not worry about, you can do any change inside, because we can reset it to default in a few minitue
    4.If you have any question,please send email to me or leave the message at Aruba community,Thanks for your help
    5.In fact we have called China 400 support, and get very sadness reply, China Tec know only Money, and Know less about Aruba product and Tec, They even not sure about if RAP need PEF Lic (in fact RAP do not need PEF lic, but RAP with Split-Tunnel need PEF Lic)
  • 7.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Jul 01, 2018 09:55 PM
    (AOS83) [mynode] #show ap database
    AP Database
    Name Group AP Type IP Address Status Flags Switch IP Standby IP
    Flags: 1 = 802.1x authenticated AP use EAP-PEAP; 1+ = 802.1x use EST; 1- = 802.1x use factory cert; 2 = Using IKE version 2
    (AOS83) [mynode] #show ap-group
    default
    NoAuthApGroup
    rap
    <profile-name> Profile name
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show ap-group rap
    AP group "rap"
    Parameter Value
    Virtual AP ArubaRAP
    802.11a radio profile default
    802.11g radio profile default
    Ethernet interface 0 port configuration default
    Ethernet interface 1 port configuration default
    Ethernet interface 2 port configuration shutdown
    Ethernet interface 3 port configuration shutdown
    Ethernet interface 4 port configuration shutdown
    AP system profile default
    AP multizone profile default
    802.11a Traffic Management profile N/A
    802.11g Traffic Management profile N/A
    Regulatory Domain profile default
    RF Optimization profile default
    RF Event Thresholds profile default
    IDS profile default
    Mesh Radio profile default
    Mesh Cluster profile N/A
    Provisioning profile N/A
    AP authorization profile N/A
    (AOS83) [mynode] #show wlan virtual-ap
    ArubaRAP
    default
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show wlan virtual-ap arubaRAP
    Virtual AP profile "ArubaRAP"
    Parameter Value
    AAA Profile ArubaRAP
    802.11K Profile default
    Hotspot 2.0 Profile N/A
    Virtual AP enable Enabled
    VLAN 1
    Forward mode tunnel
    SSID Profile ArubaRAP
    Allowed band all
    Band Steering Disabled
    Cellular handoff assist Disabled
    Openflow Enable Enabled
    Steering Mode prefer-5ghz
    Dynamic Multicast Optimization (DMO) Disabled
    Dynamic Multicast Optimization (DMO) Threshold 6
    Drop Broadcast and Multicast Disabled
    Convert Broadcast ARP requests to unicast Enabled
    Authentication Failure Blacklist Time 3600 sec
    Deny inter user traffic Disabled
    Deny time range N/A
    DoS Prevention Disabled
    HA Discovery on-association Enabled
    Mobile IP Enabled
    Preserve Client VLAN Disabled
    Remote-AP Operation standard
    Station Blacklisting Enabled
    Strict Compliance Disabled
    VLAN Mobility Disabled
    WAN Operation mode always
    FDB Update on Assoc Disabled
    WMM Traffic Management Profile N/A
    Anyspot profile N/A
    (AOS83) [mynode] #show aaa profile
    ArubaRAP
    default
    default-dot1x
    default-dot1x-psk
    default-iap-aaa-profile
    default-mac-auth
    default-open
    default-tunneled-user
    default-xml-api
    NoAuthAAAProfile
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show aaa profile arubaRAP
    AAA Profile "ArubaRAP"
    Parameter Value
    Initial role authenticated
    MAC Authentication Profile N/A
    MAC Authentication Default Role guest
    MAC Authentication Server Group default
    802.1X Authentication Profile N/A
    802.1X Authentication Default Role guest
    802.1X Authentication Server Group N/A
    Download Role from CPPM Disabled
    Set username from dhcp option 12 Disabled
    L2 Authentication Fail Through Disabled
    Multiple Server Accounting Disabled
    User idle timeout N/A
    Max IPv4 for wireless user 2
    RADIUS Accounting Server Group N/A
    RADIUS Roaming Accounting Disabled
    RADIUS Interim Accounting Disabled
    RADIUS Acct-Session-Id In Access-Request Disabled
    XML API server N/A
    RFC 3576 server N/A
    User derivation rules N/A
    Wired to Wireless Roaming Enabled
    Reauthenticate wired user on VLAN change Disabled
    Device Type Classification Enabled
    Enforce DHCP Disabled
    PAN Firewall Integration Disabled
    Open SSID radius accounting Disabled
    (AOS83) [mynode] #show wlan ssid-profile
    ArubaRAP
    default
    | Output Modifiers
    <cr>
    (AOS83) [mynode] #show wlan ssid-profile arubaRAP
    SSID Profile "ArubaRAP"
    Parameter Value
    SSID enable Enabled
    ESSID ArubaRAP
    WPA Passphrase N/A
    Encryption opensystem
    Enable Management Frame Protection Disabled
    Require Management Frame Protection Disabled
    DTIM Interval 1 beacon periods
    802.11a Basic Rates 6 12 24
    802.11a Transmit Rates 6 9 12 18 24 36 48 54
    802.11g Basic Rates 1 2
    802.11g Transmit Rates 1 2 5 6 9 11 12 18 24 36 48 54
    Station Ageout Time 1000 sec
    Max Transmit Attempts 8
    RTS Threshold 2333 bytes
    Short Preamble Enabled
    Max Associations 64
    Wireless Multimedia (WMM) Disabled
    Wireless Multimedia U-APSD (WMM-UAPSD) Powersave Enabled
    WMM TSPEC Min Inactivity Interval 0 msec
    DSCP mapping for WMM voice AC (0-63) N/A
    DSCP mapping for WMM video AC (0-63) N/A
    DSCP mapping for WMM best-effort AC (0-63) N/A
    DSCP mapping for WMM background AC (0-63) N/A
    WMM Access Class of EAP traffic default
    Multiple Tx Replay Counters Enabled
    Hide SSID Disabled
    Deny_Broadcast Probes Disabled
    Local Probe Request Threshold (dB) 0
    Auth Request Threshold (dB) 0
    Disable Probe Retry Enabled
    Battery Boost Disabled
    WEP Key 1 N/A
    WEP Key 2 N/A
    WEP Key 3 N/A
    WEP Key 4 N/A
    WEP Transmit Key Index 1
    WPA Hexkey N/A
    Maximum Transmit Failures 0
    EDCA Parameters Station profile N/A
    EDCA Parameters AP profile N/A
    BC/MC Rate Optimization Disabled
    Rate Optimization for delivering EAPOL frames Enabled
    Strict Spectralink Voice Protocol (SVP) Disabled
    High-throughput SSID Profile default
    802.11g Beacon Rate default
    802.11a Beacon Rate default
    Video Multicast Rate Optimization default
    Advertise QBSS Load IE Disabled
    Advertise Location Info Disabled
    Advertise AP Name Disabled
    Traffic steering from WLAN to cellular Disabled
    802.11r Profile N/A
    Enforce user vlan for open stations Disabled
    Enable OKC Enabled
    In Fact, we use the role logon frist, and change to authenticated, because we think if there are some limits for logon ?
    (AOS83) [mynode] #show rights authenticated
    Valid = 'Yes'
    CleanedUp = 'No'
    Derived Role = 'authenticated'
    Up BW:No Limit Down BW:No Limit
    L2TP Pool = rap_pool1
    PPTP Pool = default-pptp-pool
    Number of users referencing it = 0
    Periodic reauthentication: Disabled
    DPI Classification: Enabled
    Youtube education: Disabled
    Web Content Classification: Enabled
    IP-Classification Enforcement: Enabled
    ACL Number = 79/0
    Openflow: Enabled
    Max Sessions = 65535
    Check CP Profile for Accounting = TRUE
    Application Exception List
    Name Type
    Application BW-Contract List
    Name Type BW Contract Id Direction
    access-list List
    Position Name Type Location
    1 global-sacl session
    2 apprf-authenticated-sacl session
    3 ra-guard session
    4 allowall session
    5 v6-allowall session
    global-sacl
    Priority Source Destination Service Application Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan IPv4/6 Contract
    ra-guard
    1 user any icmpv6 rtr-adv deny Low 6
    allowall
    1 any any any permit Low 4
    2 any any any-v6 permit Low 6
    v6-allowall
    1 any any any-v6 permit Low 6
    Expired Policies (due to time constraints) = 0
  • 8.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Jul 02, 2018 04:11 AM
  • 9.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Jul 02, 2018 02:23 AM
    Dear Kapildev
    You can try to access our public ip 47.104.193.111 again, We have improve our bandwidth to 20M
  • 10.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Jul 02, 2018 04:33 AM
    Jul 2 16:02:50 authmgr[3916]: <522125> <3916> <WARN> |authmgr| Could not create/find bandwidth-contract for user, return code (-11).
    Jul 2 16:02:50 isakmpd[3839]: <103015> <3839> <INFO> |ike| IKE Main Mode Phase 1 succeeded for peer 111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103022> <3839> <INFO> |ike| IKE Quick Mode succeeded for peer 111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103033> <3839> <INFO> |ike| IKE Quick Mode succeeded internal 172.16.200.20, external 111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103047> <3839> <INFO> |ike| IKE XAuth succeeded for 172.16.200.20 (External 111.37.21.182) for authenticated
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| ike_auth.c:ike_auth_get_key:612 Found isakmp policy for peer 0.0.0.0 client:yes
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| sa.c:sa_setup_arubaap_expirations:2512 Setting short IKE SA for our AP external IP 111.37.21.182 until 2nd IPSEC rekey
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_main_mode.c:responder_send_ID_AUTH:260 Updated Phase1 port 25649->25649
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_main_mode.c:responder_send_ID_AUTH:280 finished
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1.c:ike_phase_1_recv_ID:2218 received IKE ID Type 11 exchange:111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1.c:ike_phase_1_recv_KE_NONCE:1358 Responder, enabling NAT-T.
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1.c:ike_phase_1_responder_recv_SA:1037 Ike Phase 1 received SA
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1.c:ike_phase_1_responder_recv_SA:884 Recvd VPN IKE Phase 1 SA transform negotiation (1st packet) from IP
    111.37.21.182.
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1.c:ike_phase_1_responder_recv_SA:913 Found our AP vendor ID from external IP 111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_quick_mode.c:ike_phase_2_validate_prop_for_client:3328 Skipping crypto map default-ikev2-dynamicmap
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_quick_mode.c:ike_phase_2_validate_prop_for_client:3328 Skipping crypto map default-rap-ipsecmap
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_quick_mode.c:ike_phase_2_validate_prop_for_client:3332 Trying crypto map default-dynamicmap
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_quick_mode.c:responder_recv_HASH_SA_NONCE:2726 message negotiation succeeded
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc.c:ipc_auth_xauth:6013 ipc_auth_xauth user=arubarap, pass=******
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc.c:ipc_modify_sb_data:4697 IPSEC dst_ip=172.16.200.20, dst_mask 0.0.0.0 inner_ip 172.16.200.20 client:yestrusted:no, Master-
    Local:no
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc.c:ipc_print_dp_packet:5443 DP: :TUNNEL::SA_ADD::L2TP: OFF::incoming::ESP::AES256::Auth = SHA1:, SPI A446CA00, OPPSPI
    37520600, esrc 111.37.21.182, edst_ip 172.31.4.51, dst_ip 172.16.200.20, natt 1, natt_dport 1680932864, l2tp_
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc.c:ipc_print_dp_packet:5443 DP: :TUNNEL::SA_ADD::L2TP: OFF::outgoing::ESP::AES256::Auth = SHA1:, SPI 37520600, OPPSPI
    A446CA00, esrc 172.31.4.51, edst_ip 111.37.21.182, dst_ip 172.16.200.20, natt 1, natt_dport 1680932864, l2tp_
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc.c:is_HA_crypto_map_present:2789 Looking for MAP default-ha-ipsecmap::
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> nat_traversal.c:nat_t_exchange_add_nat_d:390 NAT-T added hashes for src=172.31.4.51:4500, dst=111.37.21.182:4500
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> nat_traversal.c:nat_t_exchange_check_nat_d_has_us:656 Did not find our matching NAT-D payload for Port:500 in their packet
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> nat_traversal.c:nat_t_exchange_check_nat_d_has_us:666 Did not find our matching NAT-D payload for Port:4500 in their packet
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> nat_traversal.c:nat_t_generate_nat_d_hash:274 IP 111.37.21.182 Port 12644
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> nat_traversal.c:nat_t_generate_nat_d_hash:274 IP 172.31.4.51 Port 37905
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> nat_traversal.c:nat_t_generate_nat_d_hash:274 IP 172.31.4.51 Port 62465
    Jul 2 16:02:50 isakmpd[3839]: <103060> <3839> <DBUG> |ike| 111.37.21.182:25649-> sa.c:ike_sa_setup_ph2complete_timer:3454 SA 0x2bb0bb0 ph2-completion timeout in 30 seconds
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| *** ipc_auth_recv_packet user=arubarap, pass=******, result=0 exch:0x2bb3220, exch-innerip:0 l2tp_pool:rap_pool1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| GetFirstMatchIsakmpPSK: entering
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ike_phase_1_post_exchange_KE_NONCE IV len:16
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ike_phase_1_post_exchange_KE_NONCE done 111.37.21.182 g_x_len:128 skeyid_len:20
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_auth_recv_packet Inner-ip 172.16.200.20 from L2TP pool rap_pool1, DNS1:0.0.0.0, DNS2:0.0.0.0, WINS1:0.0.0.0, WINS2:0.0.0.0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_auth_recv_packet calling client_auth_ip_up for InnerIP 172.16.200.20:
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_auth_recv_packet cookie:1013654840 innerip 0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_auth_recv_packet innerip:172.16.200.20 user-pool:rap_pool1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_auth_recv_packet pool rap_pool1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_auth_recv_packet sa src=0xac1f0433, dst=0x6f2515b6
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| mask 0, ip 6F2515B6, key_ip 0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| xauth_responder_send_statusset peer:111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| xauth_responder_send_userreq peer:111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> Added the incoming IPSEC SA --- DONE !!
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> Added the outgoing IPSEC SA --- DONE !!
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ->Delete DOI_MIN Exchange ic 7aac704ef47ec136 rc 49eb0cd32b44f79d
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> Aruba RAP detected
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> Legacy IKE Fragmentation
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> New(2) ID_PROT Exchange ic 7aac704ef47ec136 rc 49eb0cd32b44f79d
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> Passing iptunnel as 0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> attribute_p2_unacceptable: no lifetime is configured in the map lifetime_units 1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> attribute_p2_unacceptable: save_type = 1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> exchange_setup_p1: ID is IPv4
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> exchange_setup_p1: USING exchange type ID_PROT
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> exchange_update_iv: udpating exch 0x2bb3220 from 0x7ea5cdf6 to 0xe3e824cb
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> get_rate_limit_val: File /flash/config/ikeRateLimit.txt does not exists, assuming rate limit of 8/sec
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> got password=******
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> got user=arubarap, pass=******
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> got username=arubarap
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> group_get entered id:2
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> group_get group:0x2bb1810
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> group_get ike_group:0x7d05e8
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_auth_hash
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1_recv_ID_AUTH for peer:111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1_responder_send_SA_NAT_T Accepted 1 of the Proposals, sending Response for exchange:111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1_send_AUTH
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1_send_ID 111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_1_send_KE_NONCE 111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_2_validate_prop_for_client sa is valid sa-phase 2 isakmpd_sa is valid isakmpd_sa phase 1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ike_phase_2_validate_prop_for_client setting lifetime_units 1 in isakmpd sa curr_map default-dynamicmap
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ikev1_same_sa: cookies are the same
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc_auth_xauth exch:0x2bb3220 exip:0 extype:6 cookie:1013654840
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc_ike_recv_packet: RAP increment session-count 1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc_setup_ipsec_dp_sa add=1, out=0, sa=0x2bb5fb0, proto=0x2bb6bf0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc_setup_ipsec_dp_sa add=1, out=1, sa=0x2bb5fb0, proto=0x2bb6bf0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipc_setup_ipsec_dp_sa sa src=0xac1f0433, dst=0x6f2515b6
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_decode_attribute: lifetype 1 sa->lifetime_units = 1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_decode_transform: SUCCESS
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_decode_transform: transform 1 chosen
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_finalize_exchange: src_net 0.0.0.0 src_mask 0.0.0.0 dst_net 172.16.200.20 dst_mask 255.255.255.255 tproto 0 sport 0 dport 0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_handle_leftover_payload: calling mac_hash_tbl entry id_i 24:DE:C6:CB:79:40
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_handle_leftover_payload: isarubaCampusAp 0 or isarubaAP 1 phase 1 id_i_len 21 ike_auth 65001
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_handle_leftover_payload: received INITIAL-CONTACT
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_sa 0x2bb6660, proto 0x2bb6bf0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_spi_hash_tbl_entry_add: adding IPSEC spi 0xca46a4 to SPI hash table
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> ipsec_spi_hash_tbl_entry_add: successfully added IPSEC spi 0xca46a4 to SPI hash table
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> length of attribute is 24
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> length of attribute is 8
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> mac_hash_tbl_entry_add: Cookies : Initiator cookie:7aac704ef47ec136 Responder cookie:49eb0cd32b44f79d
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> mac_hash_tbl_entry_add: added sa entry to sa list and then added new mac entry to MacHashTable
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> mac_hash_tbl_entry_add: adding mac hash table entry for user 24:DE:C6:CB:79:40 version 1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> mac_hash_tbl_entry_add: adding new mac entry
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> mac_hash_tbl_entry_add: converted mac : 24:de:c6:cb:79:40
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> mac_hash_tbl_entry_add: deleting old sas
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> mac_hash_tbl_entry_add: found an existing mac entry salist numOfNodes 1
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> message_recv enabling early NATT since peer initiates on 4500
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> message_recv recvd packet on UDP 4500, therefore enable NATT
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> modp_create_exchange: entered
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> modp_init entered
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> nat_t_exchange_check_nat_d_has_us src-port:500 dst-port:25649
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> new length of attribute is 24
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> pf_key_v2_enable_sa isainnerip 172.16.200.20
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> pf_key_v2_enable_sa rekeying 0 saxauthip 0 isainnerip 0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> pf_key_v2_enable_sa saxauthip 0.0.0.0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> post_quick_mode keymat:0 len:52
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> post_quick_mode keymat:1 len:52
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> responder_send_ID_AUTH pskCount 0, newPsk 0
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> xauth_responder_recv_ipreq peer:111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> xauth_responder_recv_statusack peer:111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> xauth_responder_recv_userrep peer:111.37.21.182
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> xauth_responder_send_iprep peer:111.37.21.182 innerip:172.16.200.20
    Jul 2 16:02:50 isakmpd[3839]: <103063> <3839> <DBUG> |ike| 111.37.21.182:25649-> xauth_responder_send_iprep: Sending Aruba LMS IP 52.4.31.172 (We are not sure where is this ip come from ? we never input this IP in our VMC)
    Jul 2 16:03:10 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ->Delete ID_PROT Exchange ic 7aac704ef47ec136 rc 49eb0cd32b44f79d
    Jul 2 16:03:10 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ->Delete TRANSACTION Exchange ic 7aac704ef47ec136 rc 49eb0cd32b44f79d
    Jul 2 16:03:10 isakmpd[3839]: <103063> <3839> <DBUG> |ike| modp_free entered
    Jul 2 16:03:34 isakmpd[3839]: <103060> <3839> <DBUG> |ike| ipc.c:ipc_rcvcb:3295 pubsub msg
    Jul 2 16:04:01 cli[5021]: USER: admin connected from 111.37.21.182 has logged out.
    Jul 2 16:06:34 isakmpd[3839]: <103060> <3839> <DBUG> |ike| ipc.c:ipc_rcvcb:3295 pubsub msg
    Jul 2 16:08:17 isakmpd[3839]: <103040> <3839> <INFO> |ike| IKE XAuth idle timeout for 172.16.200.20 (External 182.21.37.111)
    Jul 2 16:08:17 isakmpd[3839]: <103056> <3839> <INFO> |ike| IKE XAuth client down IP:172.16.200.20 External 111.37.21.182
    Jul 2 16:08:17 isakmpd[3839]: <103060> <3839> <DBUG> |ike| ipc.c:ipc_modify_sb_data:4697 IPSEC dst_ip=172.16.200.20, dst_mask 0.0.0.0 inner_ip 172.16.200.20 client:yestrusted:no, Master-Local:no
    Jul 2 16:08:17 isakmpd[3839]: <103060> <3839> <DBUG> |ike| ipc.c:ipc_print_dp_packet:5443 DP: :TUNNEL::SA_DEL::L2TP: OFF::incoming::ESP::AES256::Auth = SHA1:, SPI A446CA00, OPPSPI 37520600, esrc
    Jul 2 16:08:17 isakmpd[3839]: <103060> <3839> <DBUG> |ike| ipc.c:ipc_print_dp_packet:5443 DP: :TUNNEL::SA_DEL::L2TP: OFF::outgoing::ESP::AES256::Auth = SHA1:, SPI 37520600, OPPSPI A446CA00, esrc
    Jul 2 16:08:17 isakmpd[3839]: <103060> <3839> <DBUG> |ike| ipc.c:ipc_rcvcb:3587 Auth ip down message.ip=172.16.200.20. flags 1
    Jul 2 16:08:17 isakmpd[3839]: <103060> <3839> <DBUG> |ike| ipc.c:ipc_rcvcb:3602 sa_xauth_down ok for ip20.200.16.172 flags 1
    Jul 2 16:08:17 isakmpd[3839]: <103060> <3839> <DBUG> |ike| sa.c:sa_xauth_down:2727 RET 1 for ip 2.0.0.0 flag 1
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| Deleted the incoming IPSEC SA --- DONE !!
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| Deleted the outgoing IPSEC SA --- DONE !!
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| Passing iptunnel as 0
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| freeL2TPIP freeing IP 172.16.200.20 from pool
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ikev1_same_sa: cookies are the same
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_setup_ipsec_dp_sa add=0, out=0, sa=0x2bb5fb0, proto=0x2bb6bf0
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_setup_ipsec_dp_sa add=0, out=1, sa=0x2bb5fb0, proto=0x2bb6bf0
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipc_setup_ipsec_dp_sa sa src=0xac1f0433, dst=0x6f2515b6
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipsec_sa 0x2bb6660, proto 0x2bb6bf0
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| ipsec_spi_hash_tbl_entry_remove: Successfully removed IPSEC spi 0xca46a4 from SPI hash table
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| mac_hash_tbl_delete_sa_entry: deleting for mac 24:DE:C6:CB:79:40
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| sa_free: 172.16.200.20 not found in InnerIPHashTable
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| sa_release phase:1 calling client_auth_ip_down with ip=0xac10c814, extip=0x6f2515b6
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| sa_release-> SA ph:1 ref:0 flags:10583 ic 7aac704ef47ec136 rc 49eb0cd32b44f79d
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| sa_release-> SA ph:2 ref:0 flags:10583 ic 7aac704ef47ec136 rc 49eb0cd32b44f79d
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| sa_release: Removing spi 0xca46a4 from spi hash table
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| sa_release: calling mac_hash_tbl_delete_sa_entry id_i 24:DE:C6:CB:79:40
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| sa_release: decrement limit 0
    Jul 2 16:08:17 isakmpd[3839]: <103063> <3839> <DBUG> |ike| sa_release: sa->isarubaAP 1 isarubaCampusAP 0 sa->id_i_len 21
    Jul 2 16:08:17 isakmpd[3839]: <103101> <3839> <INFO> |ike| IPSEC SA deleted for peer 111.37.21.182
    Jul 2 16:08:44 cli[6217]: USER: admin has logged in from 111.37.21.182.
  • 11.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Nov 06, 2019 01:53 PM
    Very useful, thanks a lot.
    I drawn a flowchart for your configuration. I share it with you.
    Q:
    Please, what will be the configuration changes in a topology with a Firewall and NAT, liken in the graphic?
  • 12.  RE: ArubaOS 8 - Setting up Remote Access Point (RAP)
    Posted Jun 26, 2020 06:15 PM
    Quick question. For these 303H deployed as RAPs, in the system-profile, can we configure parameters for bluetooth console access: 'ble-op-mode persistentConsole'. Has anyone tested this to be working?
