ArubaOS 8.12 procedure for uploading a captive-portal logo or certificate using CLI
  • 1.  ArubaOS 8.12 procedure for uploading a captive-portal logo or certificate using CLI
    Posted 6 days ago
    I've tested this on several different models including AP-635, AP-505, et c.  running:
    ArubaOS (MODEL: 505), Version 8.12.0.5 SSR
    I need to be able to upload an internal captive-portal logo image using CLI.  The CLI guide says this:
    apply cplogo-install tftp://192.168.1.47:/var/lib/tftpboot/logos/mylogo.png
    but nothing happens. No message, no error, no image upload.
    Similar issue for captive-portal certificate:
    download-cert cp tftp://192.168.1.47:/var/lib/tftpboot/certs/mycert.pem
    download-cert ?
    ap1x
    ap1xca
    The download-cert command doesn't even seem to contain the "cp" option.
    I've already verified that I am in "Priviledged EXEC mode" (not config mode).
    Suggestions?
  • 2.  RE: ArubaOS 8.12 procedure for uploading a captive-portal logo or certificate using CLI
    Posted 6 days ago
    I think the easiest way would be to use the WebUI, when configuring the guest WLAN
