2 different issues here, I've had a support ticket open a couple weeks but trying here to see if anyone has ideas. This is Aruba 8.3 with 3 x 7210's in a cluster. Redudancy is on.
1. The client count per controller is severely unbalanced. For example, today I had almost 6000 clients on one controller, 160 on another and about 30 on another. From my reading these controllers handle about 16,000 clients, with redundancy cutting that in half to 8,000. My settings are at the default of 50% active, 75% standby, 5% unbalance. That means 4000 active, 6000 standby, 400 unbalance and it moves. Why in the world isn't it moving some of those 6000 off of the controller?
2. At about the same 30 minute timeframe, a couple times per week, the controller that has 95% percent of the clients on it (see above) decides to move all of them off to another controller. It moves them all to another controller, then about 30 minutes later, they all get moved back to the controller they were previously on. See the above image. I'm assuming here, that it is missing heartbeats and moving them off? The controllers are all sitting on top of each other in the same rack with ping times sub 1ms over 10Gb.
Cluster Heartbeat Counters
IPv4 Address RES RSR MIS HMPD LMRPD IDPD CPDPD CDPD LMHINT LTOD
10.10.10.5 170462 170462 0 4 1 0 0 0 396 Wed Oct 3 10:34:11 2018
10.10.10.6 170498 170443 55 3 2 0 0 0 394 Wed Oct 3 10:34:11 2018
10.10.10.5 171119 171059 60 4 1 0 0 0 383 Wed Oct 3 10:34:11 2018
10.10.10.7 188868 188803 65 4 0 0 0 0 378 Wed Oct 3 10:00:33 2018
