What do you have on the log ?
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Feb 18, 2022 04:26 AM
Subject: ArubaOS 8.5 Wlc CPSec issue
Yes if You mean Campus AP whitelisting, its there
Juha-Pekka Lepp�nen
Original Message:
Sent: Feb 18, 2022 04:24 AM
do you have trust the AP ?
Original Message:
Sent: Feb 17, 2022 06:15 AM
Hi
I've issue regarding CPSec. We are moving and migrating old 6.5 WLCs to new 8.6 and need to change SSID on Bridge mode. Now, Bridge mode requires CPSec and if enabled AP is going to Down mode.
Campus AP is joining fine if CPSec is Disabled
Right away when I enable CPSec AP is Down.
Firewall is between but has permit IP any any between AP networks and WLC's.
Environment
2 Standalone controllers (7210's) with L2 redundancy (VRRP)
OS 8.6.0.15
#show tpm errorlog
Could not find any Error Logs for TPM and Certificates.
#show ap database
Name Group AP Type IP Address Status Flags Switch IP Standby IP
test-ap1 gropup 205 10.36.30.9 Down 172.29.105.3 0.0.0.0
AP is joining to VRRP IP .2, active host WLC is .3
Pls advice next troubleshooting steps or solution if You have already solved it.
Br
Juha-Pekka
Juha-Pekka Lepp�nen
