You only need the mobility conductor if you want to use a controller cluster with activ/activ and AP and user load balancing.
For HA-Group redundancy you do not need a mobility conductor. You can configure it the same way as in the OS 6 environment. Here is a link with configuration example.
good luck
Waldemar
ACCX # 1377, ACEP, ACA - Network Security
Original Message:
Sent: Mar 24, 2023 07:46 AM
Subject: Arubaos 8.6 Standalone Master-Standby HA
Hi
Yes this is done already. I was looking how to make HA to allow seamless and fast AP tunnel failover to Stanby but it requires Mobility Master to maintain active and backup tunnels
Juha-Pekka
Original Message:
Sent: Mar 24, 2023
Subject: RE: Arubaos 8.6 Standalone Master-Standby HA
You would have to configure "master redundancy" and point the access points to the VRRP in the AP System Profile (LMS-IP). In this setup, there are no backup tunnels; the status of the VRRP determines which controller is actually the master and can accept access points. The access points point to the VRRP, so that they connect to the same ip address upon failover.
Original Message:
Sent: Mar 23, 2023 03:56 PM
SOLVED.
Hi
On Arubaos Wlc 6.5.x I can configure HA Group to allow APs make backup tunnel to Standby Wlc
Is this possible with 8.6?
No Mobility Masters used or wanted?
If Yes pls provide link to setup documentation
I tried to do it but no backup tunnels were up
Pls advice
Br
Juha-Pekka
