Wired Intelligent Edge
ArubaOS-CX and ClearPass?
  • 1.  ArubaOS-CX and ClearPass?
    Posted Dec 07, 2019 05:29 AM
    Hi there,
    I just read the Security Guide for the new 6300m, and it seems to be missing some info on how to setup AAA to integrate with ClearPass. Also, ClearPass itself also seems to be missing support for the new AOS-CX.
    And missing support for device-fingerprinting.
    Info I miss on the docs:
    - How to enter CPPM info to the switch, so that it can download user roles? It seems to be missing the "radius-server cppm identity user key password" command.
    - What "product" should I select under ClearPass for Aruba Downloadable Role Enforcement, as it only has "ArubaOS-Switch", "Mobility Access Switch", "Mobility Controller". What kind of role syntax does AOS-CX accept?
    - How to enable the switch to forward DHCP, CDP, LLDP, HTTP User-Agent info to Clearpass to support Device Fingerprinting (the equivalent to "device-fingerprinting policy <policy> \_ dhcp http lddp cdp")? Is this supported with 10.4?
