We're currently using two 6300M switches to connect to two 10G CPE's from a internet provider. both with theire own /30 subnet and both within the same public AS. On customer side we use a single private AS.
On the first link we receive a 0.0.0.0 route with a metric of 0, on the second link we get a route 0.0.0.0 with a metric of 1000.
Somehow the second switch doesn't seem to like it. The 0.0.0.0 apears and disapears.
Iteration : 90 Command : show ip route
Displaying ipv4 routes selected for forwarding
Origin Codes: C - connected, S - static, L - local
R - RIP, B - BGP, O - OSPF
Type Codes: E - External BGP, I - Internal BGP, V - VPN, EV - EVPN
IA - OSPF internal area, E1 - OSPF external type 1
E2 - OSPF external type 2
VRF: default
Prefix Nexthop Interface VRF(egress) Origin/ Distance/ Age
Type Metric
0.0.0.0/0 1xx.1yy.200.185 1/1/27 - B/E [20/1000] 00h:10m:51s
1xx.1yy.198.96/27 - vlan144 - C [0/0] -
1xx.1yy.198.99/32 - vlan144 - L [0/0] -
1xx.1yy.200.184/30 - 1/1/27 - C [0/0] -
1xx.1yy.200.186/32 - 1/1/27 - L [0/0] -
Total Route Count : 5
Iteration : 91 Command : show ip route
VRF: default
Type Metric
Total Route Count : 4
Iteration : 92 Command : show ip route
VRF: default
Type Metric
0.0.0.0/0 1xx.1yy.200.185 1/1/27 - B/E [20/1000] 00h:10m:55s
Did anyone experience this one before? When I test in my lab with virtual cx switches its seems to start when I add a metric to the second connection.
With kind regards,
Rens
Rens Kluitmans
