Wired Intelligent Edge
  • 1.  ArubaOS-CX OSPF
    Posted Feb 07, 2020 05:49 AM
    I am currently trying to convert our Core switch configuration from a Comware to ArubaOS-CX. I have used the exact same set up north & south of the switch i.e. same hardware, cabling, configurations however, I am struggling to get ospf working.
    I have two VRF's at this stage. The ospf process within the default VRF is working as expected, no issues at all. The ospf process within the named VRF however, will not come up at all.
    For the purpose of this test I have two transits, 1 per VRF, running up the same trunk port to a Firewall.
    NOT WORKING:
    interface vlan10
        vsx-sync active-gateways
        description NAMED Transit
        vrf attach NAMED
        ip address 10.x.x.x/29
        active-gateway ip 10.x.x.x mac 00:00:00:00:00:10
        ip ospf 30 area 0.0.0.0
    router ospf 30 vrf NAMED
       trap-enable
       redistribute connected
       redistribute static
       area 0.0.0.0
       interface vlan10
    WORKING:
    interface vlan20
        description Transit
        active-gateway ip 10.x.x.x mac 00:00:00:00:00:20
        ip ospf 40 area 0.0.0.0
    router ospf 40
       trap-enable
       redistribute static
       area 0.0.0.0
       interface vlan20
    Has anyone come across any similar issues? Am I missing something simple?
    Note: I know the configuration on the attached Firewall is correct and I can see it trying to establish a connection to the switch for both the working and not working ospf process.
  • 2.  RE: ArubaOS-CX OSPF
    Posted Feb 07, 2020 10:27 AM
    What do you have on show ip ospf ? (and different stuff)
  • 3.  RE: ArubaOS-CX OSPF
    Posted Feb 21, 2020 05:21 AM
    Hi Alagoutte
