Wired Intelligent Edge
  • 1.  ArubaOS-CX Radius auth using Microsoft NPS
    Posted Sep 16, 2024 03:01 PM
    I have been attempting to follow Aruba AOS-CX – RADIUS Authentication with Microsoft NPS | Wired Intelligent Edge (arubanetworks.com).
    Nothing positive has resulted so far.  Using WireShark, I see the request making it to the NPS server, but that server continually rejects the request.  See this.
    Sample Wireshark Result of Rejection
    Any ideas?
  • 2.  RE: ArubaOS-CX Radius auth using Microsoft NPS
    Posted Sep 17, 2024 02:08 AM
    Hello, you can see more details in the event viewer on the Windows Server where NPS is installed.
    Most likely there are some mismatches in configuration between the switch and NPS but would need more detailed information what your configuration looks like.
  • 3.  RE: ArubaOS-CX Radius auth using Microsoft NPS
    Posted Sep 17, 2024 01:41 PM
    Chris,
    Thanks for the quick response.  Do you need a copy of the running config?  Is there anything you need from NPS?
  • 4.  RE: ArubaOS-CX Radius auth using Microsoft NPS
    Posted Sep 17, 2024 04:59 PM
    The Code Access-Reject is NPS rejecting the authentication.
    You can check the Event Viewer under Custom Views ->  Server Roles Network Policy Server to see the access reject information.
    Could be bad user/pass, user not in the AD group your looking from in the conditions or one of the other conditions in NPS not policy not being met.
  • 5.  RE: ArubaOS-CX Radius auth using Microsoft NPS
    Posted Sep 20, 2024 09:14 AM
    Checked there already.  It says bad username and password, but I can use the same username and password to sign into AD from a server
  • 6.  RE: ArubaOS-CX Radius auth using Microsoft NPS
    Posted Sep 23, 2024 06:29 AM
    I'm not an NPS expert, but think there has been hardening of Active Directory over time including access to password information. You may need to relax the security settings, or add your switch as a logon location for the account. Also make sure that you configured PAP for your authentication (not CHAP/MSCHAP). Maybe Microsoft support can assist you to find the issue?
  • 7.  RE: ArubaOS-CX Radius auth using Microsoft NPS
    Posted Sep 25, 2024 02:57 AM
    I think it is recommended to use EAP-TLS instead.
    There were a view patches in the last view months because of some vulnerabilities in the radius protocol.
