Wired Intelligent Edge
  • 1.  ArubaOS-CX Radius authentication
    Posted Feb 22, 2019 09:12 AM
    I'm trying to configure radius authentication for management access on ArubaOS-CX switches with Clearpass.
    I've setup the switch as follows:
    radius-server host 10.13.111.19 vrf default
    aaa group server radius clearpass
    server 10.13.111.19 vrf default
    radius-server key plaintext mypasskey123
    radius-server auth-type chap
    aaa authentication allow-fail-through
    aaa authentication login default group clearpass local
    aaa accounting all default start-stop group clearpass
    This works but for every login attempt I get one Accept and two Reject messages.
    Does anyone know why this is happening and how to solve this?
    I'm currently using ArubaOS-CX Version TL.10.02.0001
    With kind regards,
    Rens
  • 2.  RE: ArubaOS-CX Radius authentication
    Posted Feb 22, 2019 03:20 PM
    Just curious, why aren’t you using TACACS+? It’s designed for management/admin AAA.
  • 3.  RE: ArubaOS-CX Radius authentication
    Posted Feb 23, 2019 04:50 AM
    Hello Tim,
    Tacacs was the first thing I tried. But unfortunatly I can't even get close to get that one working. Please see my other post.
    ArubaOS-CX-Tacacs-authentication
    Rens
  • 4.  RE: ArubaOS-CX Radius authentication
    Posted Feb 23, 2019 01:00 PM
    @Rensk wrote:
    With kind regards,
    Rens
    I get the same issue... (because a customer prefer to use RADIUS and not TACACS...), and i have open multi case to TAC (for ArubaCX and ClearPass...)
    and coming from ArubaCX try to discover the cipher available on RADIUS server (a feature of OpenSSH...)
    for avoid "latency" on ClearPass, you can modified a setting (i don't remenber the name...)
