i found a bug... when use "rest/v4/system/status" (or rest/v5/system/status) with stacked(orVSF) Aruba 3810 or 5400 Switches
Via the PowerArubaSW module, i the following error
PS C:\Users\alagoutte\Documents\dev\PowerArubaSW\Tests\integration> connect-arubasw 10.76.139.100 -httpOnly
Welcome on Aruba-Stack-3810M - Aruba3810M-24G-PoE+-1-sl(JL073A)
PS C:\Users\alagoutte\Documents\dev\PowerArubaSW\Tests\integration> Get-ArubaSWSystemStatus
AVERTISSEMENT : The Switch API sends an error message:
AVERTISSEMENT : Error description (code): Not Found (404)
AVERTISSEMENT : Error details: { "message": "Error 404: Not Found." }
Unable to use switch API
Au caractère C:\Users\alagoutte\Documents\dev\PowerArubaSW\PowerArubaSW\Private\Webrequest.ps1:69 : 13
+ throw "Unable to use switch API"
+ CategoryInfo : OperationStopped: (Unable to use switch API:String) [], RuntimeException
+ FullyQualifiedErrorId : Unable to use switch API
if i force v3 API => working
PS C:\Users\alagoutte\Documents\dev\PowerArubaSW\Tests\integration> (Invoke-ArubaSWWebRequest -method "get" -url "/rest/
v3/system/status").content | ConvertFrom-Json
uri : /system/status
serial_number : SG70GYW0DL
firmware_version : KB.16.05.0003
hardware_revision : JL073A
product_model : Aruba3810M-24G-PoE+-1-slot Switch(JL073A)
base_ethernet_address : @{version=MAV_EUI_48; octets=ecebb8-168ee2}
total_memory_in_bytes : 695631872
if disable stacking => work
Get the same issue with 54xx with VSF !
Try with firmware 16.05.0003/0007, 16.06.0006 and same issue !
