ArubaOS8 - trying to config interface as untrusted with ACL - getting an error
  • 1.  ArubaOS8 - trying to config interface as untrusted with ACL - getting an error
    Posted Aug 06, 2024 04:36 AM
    Hi Airheads
    Im trying to assign policy to an interface , and i would like to make the port untrusted.
    everytime im choosing an ACL with untrusted im getting an error
    "Invalid access group configuration" , And it's dosent matter with what ACL im choosing - same error.
    Please advise. i would like to make this interface 1/1 untrusted and use a specific role we created. what im doing wrong?
    (*) If i helped you , Please do kudos me as a thank you (*)
    Aruba AirHeads - Because mobility matters.
  • 2.  RE: ArubaOS8 - trying to config interface as untrusted with ACL - getting an error
    Posted Aug 07, 2024 03:53 AM
    I see the same error, although configuration (under 'Pending Changes'; open the details) appears to contain the changed policy.
    That message may be 'cosmetic'. I've not set policies on interfaces before, so don't know if this was ever different.
    If the WebUI refuses the changes, you may try to do the same through CLI and see if there is a more understandable error when you enter the commands.
    ... oh, and if you found out, please report to TAC so it can be further investigated and resolved.
